Rear swaybar diameter?
Tech Info Resource
You all are confusing spring rate with damping force. Springs don't make the suspension "stiff" the damping required to control higher rate springs makes the suspension stiff.
Swaybars are a band aid for soft springs. The progressively eliminate the independence of your independent suspension and should be the last place you look to improve handling. Everything starts with picking the spring rate that is right for your driving. There is nothing more important in basic chassis setup than spring selection.
Tech Info Resource
^^^^Yep, I disagree also, but that's another story. I put an FSport rear bar on my ISF with GREAT results. That change along with the RRRacing USRS and wider RCF wheels and wider tires (255 & 295) has dramatically improved the handling of my ISF.
BUT, can we cease all this arguing and get back on topic. I would really be interested in knowing the sway bar (Front & Rear) dimensions of the RCF. Can someone please get a mic, crawl under their RCF or GSF (yes Lance - YOU) and report here?
Lou
Lou
