Engine bay molding plastic fasteners/clip removal
Flat head screwdriver or plastic body panel remover into either recessed area. If you damage the grommet can purchase new ones.
I would cover the engine bay with a shop towel to prevent any of those clips from flying down into the bay. I had that issue and had to hunt down a clip. A flat head screw driver will do to remove them.
ISFPOWER (06-25-17)
Tech Info Resource
Clip tools work better and avoid the whole flying clip problem. The IS F has way more clips under the hood, and it seems nearly everything on the car is clipped with some kind of push pin.
I bought bags of clips as well since they tend to break very easily. There are lots of alternate sources for clips.
Clip tools work better and avoid the whole flying clip problem. I bought this set. The IS F has way more clips under the hood, and it seems nearly everything on the car is clipped with some kind of push pin.
http://Performance Tool W86561 Push Pin Pliers https://www.amazon.com/dp/B003WZTI12/ref=cm_sw_r_cp_apa_dtFuzbSBQHCFZ
r0cketm0nk
07-21-17 08:47 PM
