Invisibile Micro Chips on Windshield Appeared!!!
Hi! I used Aquapel Windshield Coating for the first time to repel water for easier cleaning. But all of a sudden invisible micro chips became not so invinsible anymore since the coating got into those micro chips. Is there any way to fill in those micro chips?
I think I saw in one of the commercials/ads that they use something to fill those mini/micro chips and they disappear. I searched in yelp but all of the reviews says windshield was replaced blah blah... Mine is not cracked or broken like theirs.
Moving forward, what I'd consider doing (I do this on all my new cars) is applying ClearPlex to the front windshield. It's plastic film protection for your windshield. I always want to retain the factory installed windshield from new.
I can't speak to whether the ClearPlex will make your micro chips more or less noticeable. Good luck, bud.
ba2sy (07-28-17)
ba2sy (07-28-17)
ba2sy (07-28-17)
Yup! that was before Aquapel. But after Aquapel, a windshield coating, they showed up which makes them visible 99% of the time. Unless, the coating wears off or is removed. I need to have my winshield rock chips free before I do another windshield coating or clearplex in the future.
Not yet. It seems like they're disappearing but there's still some that shows up.
Tech Info Resource
Don't follow trucks with sand blowing out of them.
I got a new windshield after the old one finally cracked massively, but had all the "micro" chips from following a truck spewing sand on a road trip. Wish I had a dash cam to capture that event, I would have sued for paint and glass.
There are no good fixes for tiny chips in glass or paint. Every good fix involves new glass and/or new paint.
Aquapel does nothing either way. I have used RainX and Aquapel, and neither has made sand chips more visible (or invisible which would actually be a plus IMHO). If you are really concerned, clean your windshield with 0000 steel wool to remove anything that isn't glass, then treat with your favorite water dispersant.
FYI, there is a premoistened towelette for PPG Aquapel application. Did you use it before you put the Aquapel on the glass?
