RS*R coilovers
RS*R coilovers
Ok so I have a 2016 GSF and thinking about getting the RS R coilover and I wanted to know what you guys think that have them please let me know about the pros and cons. I haven't seen anybody with a GSF with the RS R coilover thats why Im asking you guys.
Not sure if the available options that are available to the RCF will work on the GSF, but I'd contact Figs engineering and speak to Mike before going RSR. I had a set of RSR lowering springs and they would bottom out...ended up cutting a wiring harness and put me 400$ in the hole. I went Penske coils myself, but if I had to redo it I'd likely go to Mike and get the Ohlins. The Penske's have the typical coil over sound in the rear as the Ohlins do not. There are new springs that were just released for the Penske's to eliminate some of the sound ( which I just received but haven't installed yet).
13FSPORT (08-09-17)
If not looking for a hardcore track set up, I think I would do the Fig's set up since it has rubber top mounts to reduce/eliminate the noise.
Although both the penskes and Ohlins are a bit higher cost than RSR i think.
13FSPORT (08-10-17)
Been using them for almost 3 years, I am happy with them.
13FSPORT (08-10-17)
very happy with mine too. they are noiseless, comfortable but you don't lose the sporty stiffness if you set it right. i really wish i didn't have to reuse the OEM rear upper portion but I'm guessing thats the reason why its quiet.
13FSPORT (08-10-17)
You get what you pay for.
Oem will be least maintenance and silent in operation.
Once you go aftermarket you add a lot of untested variables so set your expectations with these considerations in mind. Noise. Complexity. Added cost.
Also be self critical who you get advice from. 99% of internet car guys are clueless and lazy and want to be heard. Keyboard diarrhea.
Good luck.
Good luck.
Good luck.
Good luck.
Thanks for your input there are not a lot of options out there for the GSF. I understand I get what I pay for but I'm sure that the Novel or the Tom's isn't any better then the RS*R by much at all.. I didn't see Ohilns or Penske list anything for the GSF I'm sure I can used the RCF kit.
I can personally attest that the TOMS Coilovers is 1st rate quality built...Got Pay To Play...No way around it for a quality built ride...
WHAT HE SAID, Below:
Good luck.
Good luck.
i've had my RSR on for a year and 10k miles. Still holding up fine. I thought the 36 way adjustability was overkill, but you really can fine tune your setup. Fronts are easy to do, rears requires removing trunk trim. Adjusted about 4 times until I came up with current settings; 31 front, 22 rear. This is a little more stiffer than stock. Remember, rear springs are stiffer, even in stock form. No noise yet either. I've used RSR before for springs for my G35 and the quality was good. I am patiently waiting to see if Blistein will make a coilover for the F.
The following 2 users liked this post by Deanrcf:
13FSPORT (08-12-17),
Carbon Exchange (08-14-17)
