Rcf 1/4 mile issues
Rcf 1/4 mile issues
Hey all I am a new member here. I purchased my rcf a month ago, I love the car! I have taken it to the track 3 times now and I am having some issues.
1st issue: 1/4 time.. On good runs I am hitting a consistent 13.1, where I see people running consistent 12.7-12.9, lastnight an isf ran a 12.7 completely stock while I was still 13.1. What am I doing wrong? Or is my car just slower which I hope not.. I am completely stock and running stock tires Michelin pss.
2nd issue: burnouts
I figured trying burnout would help me get traction to get better time but doing burnouts the car shifted into 2nd and wouldn't go into 1st.. I tried multiple things, traction off expert on etc, held down for 3 seconds, still have me a surface slippery message and shifted me into 2nd. Frustrating. Any advice guys?
2nd issue: burnouts
2nd issue: burnouts
2nd issue: burnouts
2nd issue: burnouts
2nd issue: burnouts
here is what you need to do to achieve those times:
1. Lower air pressure to 30psi
2. Do a decent burnout to warm up tires. If no burnout, no way to get under 2 sec 60’, especially if its cold out.
3. Drive forward 20-30 feet to unlock the slip mode, then reverse back. No other ways around it
4. Brake torque to 2k rpm
5. Turn traction off, sport mode, paddle shift
* also helps to take out useless things in trunk
* try to run only when its cool temp
Need 305 street slicks on the back, a good burnout, traction off, good brake torque (but only a moment before the light) and...oh, you need to get around the "slip". Which yes, can be disabled
You also need to open the hood vent to reduce IAT slightly.
On previous F cars it disables stability control and electronic LSD, but will not disable ABS, EBD, or BA.
Have you tested ABS with it in test mode?
In the video it appears to only shut off VSC and precollision braking, not ABS or EBD (electronic brake force distribution, essentially electronic brake proportioning), and not VDIM because VDIM includes ABS, EBD, and a couple of other brake controls along with VSC and TRAC. There is a very long detailed discussion in the FSM and NCF about VDIM, VSC, ABS, EBD, TRAC, and what these terms include. VDIM describes what amount to all driver aids, while VSC is only the stability system. Keep in mind, to shut off VSC with the switch (not just TRAC), you need to hold it for three seconds or more. See chart below for details on VDIM and Sport switch functionality:
It disables the driver abuse limits in addition to VSC and TRAC (such as excessive slip).
So how does this differ from VSC off by holding for three seconds?
nismo4life
11-27-12 12:14 PM
