Too much oil after service check on my RCF
#31
I think I figured out part of the issue. Took the car in for its 5K, handed them 9 quarts of oil for the change...watched them put in only 9 quarts.
When I checked the car at the dealership, it was full, or slightly over.....odd. Checked it at home, same thing. Should have been slightly low.
Just for the heck of it, and since I was curious, did another full change including filter. Made sure it was hot, waited until everything drained....then measured the drained oil, ~9.3 or 9.4Q. If the dealer is rushing the drain, and leaves 1/3 or more of quart in the car, then adds another 9.3, instant overfill.
Sequence in TIS is drain the sump first, then replace the plug...then drain the filter. I left the plug out and once I opened the filter cover, more oil came out of the drain plug. That might account for part of it too.
Oddly, I only added 9 quarts, intending to top off after driving, and its showing on the full dot after 10+ minutes at rest. I can't figure that one out, unless there was even more in the engine that I didn't drain, or my very minor floor slope (towards back of the car) affects it this much. For the drain, the car was on a lift, so pretty much horizontal.
#32
the oil cooler and ancillary lines are holding onto a bit, hence the huge difference in DRY fill amount... but full change with filter should be close to correct on the revised/later numbers. When I purchased my used F it had a service recently prior, and was also overfilled.
#33
The tech at the dealer will never take the time to do it exactly right - unless it was his own car. Precisely why I am fine ignoring the Dealer's free oil changes and doing them myself.
#34
I remove my filter while the sump is draining, and then let both drip dry usually for at least 30-60 minutes before I put in the new filter and start my refill process. Once I get to quart 8 I start checking the dipstick. Once I see it on the dipstick, I start the car and warm it up. Then I add oil until it is exactly halfway between the low and full mark on the dipstick. It's been consistent at 8.75 quarts to get there on each fill so far (three of them). Not sure where that extra oil is hiding - oil cooler or lines I guess. But I would overfill if I just assumed it was 9.3 quarts every time.
BossMoss (12-10-20)
#35
Just removed about a quart after an overfill. When I checked the dipstick it was a 1/3” over the hi dot. So I bought a pump for sucking out oil from the dipstick on Amazon. Worked great. Too well intact as I was not prepared how well it removed the oil and made a mess (my fault obviously). It was pretty inexpensive at $20. Just hooked it up to the battery and it drained a quarts worth in 20 seconds.
Here is the link to the pump I used. Worked out great.
Here is the pic showing my overfilled engine oil
The following 4 users liked this post by cvt:
#37
The dealer said on my RCF 2017 the dipstick shows more if they put in the prescribed amount
And this thread (and many others) is an example of why I prefer to change my own oil. Takes me an hour max, and I dont have to deal with inept “qualified” “mechanics” putting in wrong oil at the incorrect level, and forcing me to schedule another appointment after having already lost 2-3 hours on the previous one.
#38
I just did my first oil change myself on my 2017 RC F. I only added about 8.25 quarts, but I guess I didn't warm it up before checking so the level is already just below the top dot. I changed the filter and let both the filter and the drain hole drain for at least 30 mins before refilling. Tomorrow I'll warm it up and let it settle for 5+ mins and check again, see if I need to add a bit more. I suspect the 9.3qt on the manual is a bit too much, 8.75 sounds about right, so I'll probably have to add another 1/2 qt.
#39
Believe some of the variability we all see on oil fill levels is due to the fact that most of us fill up the oil filer with oil prior to screwing it on. I doubt that the dealerships are doing that. Like I stated in an earlier post, my dealership overfilled dipstick by an inch first three fills. After that, told them that please check and confirm in writing on the receipt that dipstick was correct, or I would not take back the car untill I checked it myself at the dealership. After that, next two were correct, then I started changing oil myself.
Just makes you think, I dealership can't get the oil level correct, how much brake fluid, transmission fluid, and coolant do I really have in my car? What's that line? "Trust but verify"?
#40
Just maked you think, I dealership can't get the oil level correct, how much brake fluid, transmission fluid, and coolant do I really have in my car? What's that line? "Trust but verify"?
#41
If you don't change the oil yourself on an RCF, you are pretty much guaranteed to get it overfilled. It's not a Lexus service problem, it's the RCF service manuals. Lexus never overfilled my IS350 over 5 years. Even if you do it yourself, your going to overfill if you use the 9.8 (2015) or 9.3 (2016-2021) quarts listed in the manuals.
I have a 2015 RCF and the first time I had Lexus change the oil, they put 9.8 quarts per the manual. It was WAY overfilled on the dip stick. I went back and they pulled over a quart out to get the level correct on the dip stick. The Lexus service advisor tried to tell me that performance cars burn oil, so it's ok to be overfilled. While that might be true with some older cars, that's BS for a properly broken in RCF. I don't track my car, but it regularly sees 7K RPM in Sport + Manual mode (the only way to drive an RCF) and the oil level never drops between oil changes, even after 47K miles.
9.0 quarts seems to be the amount required with a filter change.
#42
In other words, I think the 9.3 qts spec is exactly right. Maybe the engineers at Lexus do know how to measure volume
#43
The reason why the manual says 9.3 is that's if the system is completely dried. I would suspect many dealerships don't let the oil drain for long enough, and even if they did, probably over half a quart gets collected in the cooler. Cars without an air-to-oil oil cooler don't have a cooler for the oil to collect in, so that explains your IS350.
#44
Well just checked my dipstick and it was a little under 1/2 inch overfilled… just had it at the dealer Friday to perform a pre-purchase inspection and they confirmed that they “check engine oil and condition”. Clearly that didn’t happen. I’ve been driving the car very enthusiastically since I got it Wednesday, should I be concerned? Going to call up my service advisor tomorrow morning and have a little chat.
#45
While it is true that these cars are standardized, there are still tolerances in every machined part--including dipsticks and placements of the dots and sump volume, yadda yadda yadda. While the dipstick is the only indicator you have to go bye and should not be ignored try not to go ballistic if the dealership volumetric fill indicator is different than what the dipstick says.
