Air
You most likely have what I had. The passengers hose from the compressor to the shock has a hairline crack under the rubber cover at the bend of the frame. This hose leaks under the small rubber portion and you will not detect by spraying water. I found mine by removing the rubber section, replacing the hose, inflating the system then slightly bending the host at it's natural curves around the frame. I even tried to repair the hose as a replacement was $90 and took 2 weeks to come in. No luck on that. but here is a link to it.
https://www.lexuspartsoutlet.com/oem...RoCAIwQAvD_BwE
