Brake Caliper mod
Brake Caliper mod
I really want the brake calipers to stand out, as mine are currently stock black. I'm thinking about going with the original Brembo red. I saw a video the other day, of somebody placing 3M wrap on the calipers, then placing the Brembo logo over it. Have you guys seen this done? I believe it was on the murdered out RCF. I'm just curious if that will hold up to the heat the brakes generate, and how long they will hold up. I know painting them would be the best, but I didn't really want to take them off. I don't know why, just don't feel comfortable. They placed the wrap over the caliper, and only removed the tire.
What are you guys doing with your brake calipers?
https://www.clublexus.com/forums/is-...iper-wrap.html
My ISF calipers are painted. They don't need to be removed to paint.
Lou
Lou
I've done it. Fair warning, wrapping Brembos (especially the 6 pistons in the front) will make you want to commit suicide. It will hold up long term without a problem. Had it on for a year with no issues and I drive hard.
GunnyFitz (04-27-18)
Also, when the time does come and they begin to peel, I wonder how hard it will be to peel the rest off and redo.
Nice!! I mean from what I can tell, it does look really good and clean!
So you know how we have brake dust galore from our pads, I wonder how that's going to look on the color brakes :/ hmmmm. Right now with black it's masked, obviously. I'm not sure how much will stick on it. Gosh that brake dust really kills me, but I can't give up those pads for a reduction in braking ...even if it's only 20% reduction. I would take 5% reduction!! Need the brake power baby!!!
Yea I can see it being a pain. This one place wants $90 each to wrap them. I am curious how long it will last, even though it says high temperature. Or I should just have them painted. I wish they would of just done them from the beginning, like the new RCFs in orange. Granted, I do really want them in red.
If I was offered $90 each to do them again, I would say hell no.
They would probably last about 2 years from what I've seen on mine and like I said before I was operating at extremely high temps.
If you're okay with losing factory color, definitely have it painted, you don't have to powdercoat honestly unless you're perfectionist.
I also peeled/removed the wrap myself.
It honestly was not that bad, and I wouldn't mind doing it again if necessary.
There was little to no glue residue left behind when peeled carefully using a heat gun.
So... I was just reading about this on Rennlist. Apparently some of the Carrera guys are wrapping them!
https://www.youtube.com/watch?v=6Z_AeLPBpeU
He's right about 1 piece being near impossible though for an amateur.
I highly recommend staying away from wrapping your calipers. I just had my Tesla wrapped and it's not worth it. The shop I took it to said to not wrap the calipers and rims. The wrap are prone to lift at times. Also, this area takes a lot of abuse from dirt, sand, etc.
D2 website shows you how to paint them on and you can get the brake caliper paint kit for around $50. The process takes about 4 hours.
I did mine with friends and it cost me $40 for material and $10 in beer at most and it took less than 4 hours.
It was absolutely worth it, especially if you factor in the experience.
Wrap will lift if you don't kill the memory, but that applies to corners on panels too...
Another thing I did that helped prevent most of the abuse was having the calipers ceramic coated.
Lexus Enthusiasts
There are vendors and paint shops that can do incredible work on calipers, like Candy Metallic Red colors but it comes at a price. The other thing you can do is High Temperature Paint, they even have kits designed specifically for painting calipers and you dont need to remove them off the car.
Its very easy to simply spray paint calipers yourself. You just need the right, heat rated, spray paint, you remove the wheels, and pack newspaper around the calipers. I've done this on two M3's I owned, and helped a friend paint his. No way I can see the effort of wrapping them, and the limited time it will likely last being worth it. You can do all four calipers in a few hours and the paint lasts for many years, and looks perfect.
JC
JC
