Cost to install aftermarket brake pads?
GunnyFitz (04-27-18)
The calipers are set up as a quick access pad change so if you are on the track you can swap pads within minutes. Its harder to take off the wheel than it is taking off the pads. Just tap out and pull the two pins on each one and the pads literally slide out. No unbolting or anything. Dealer will charge you $200-400 in labor alone.
