Turn off the forced induction sound with the rcf?
Old 05-10-18, 08:58 PM
Xzria
Xzria's Avatar
Default Turn off the forced induction sound with the rcf?
Is there a way to turn off the forced induction sound from the engine that comes into the cabin in sport plus? I have an after market exhaust and only wanna listen to that. Not two different sounds.
Old 05-10-18, 09:46 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,504 Likes on 1,802 Posts
It is not forced induction sound since RCF is N/A. It is actually the engine sound amplified and piped into the cabin through the speaker. I believe you will have to pull a fuse to disable it.
GunnyFitz (05-11-18)
Old 05-10-18, 09:48 PM
Xzria
Xzria's Avatar
My apolgies, that's how I meant to explain it. Damn I wonder what fuse it is .
lexusrus
lexusrus's Avatar
I don't know of any way to disable the active sound controll.
Which after market exhaust system did you get?
Old 05-10-18, 09:51 PM
Xzria
Xzria's Avatar
I ended up getting the GtHaus! Damn I'd pretty much have to get a new intake or unplug something?
Old 05-11-18, 01:34 AM
lexusrus
lexusrus's Avatar
Nice. I remembered watching YouTube videos on GtHaus vs Borla before I went with Borla. GtHaus as I recall is much louder vs Borla!!! I mean Borla is plenty loud for me. I can't imagine any louder....bc I'll probably get banned from my HOA!!! LOL.
Is there a fuse one can pull to disable the fake active sound?
Old 05-11-18, 02:09 AM
Xzria
Xzria's Avatar
Thats what I want to know, Because honestly I don't really like it with the added the exhaust I have. It's two different sounds and I'd rather hear my exhaust
Old 05-11-18, 08:12 AM
kluces
9th Gear
kluces's Avatar
Default What does your Borla sound like?
I'm entertaining getting the Borla too, do you have a video w/ sound of your exhaust?
Old 05-11-18, 08:13 AM
2hvy4grvty
2hvy4grvty's Avatar
It sounds like two different sounds because it is two different sounds. Piped in is the intake sound I think.
In general intake is for in cabin sound. Exhaust is for outside people behind you.
Old 05-11-18, 09:10 AM
GunnyFitz
GunnyFitz's Avatar
Hmmm, didn't know there was such a thing as "Fake Active Sound" whatsoever?
Guess that's something I'll have to experience myself when/if the Armitryx goes thru.
Old 05-11-18, 10:52 AM
05RollaXRS
05RollaXRS's Avatar
Yes, it is nduction noise from the cold air intake box piped into the cabin that has been amplified. In sport mode, there is no additional noise piped in, but still the induction noise sound is pretty loud.
Case in point, it is a high-revving engine and it will scream at high revs as the engine makes its own noise while the exhaust makes it own noise. At high rpm, both of them are audible. On my other car, I have Injen CAI and Greddy SP2 exhaust. From 6000 - 8400 rpm, you can hear both of them very loudly when it gets into "lift" (as in high lift cam).
Old 05-11-18, 03:08 PM
weswork
weswork's Avatar
Funny, I have had the GT Haus exhaust on my car for a while and don’t notice the “enhanced” noise when in sport mode at all. Even when I have the valves closed. I am fairly certain my installers didn’t disable or unplug anything.
Old 05-11-18, 08:37 PM
GOT8SPD
GOT8SPD's Avatar
I have the borla and honestly didnt really notice the "2nd noise" , rcf engine is loud, you should want to hear both noises lol
Old 05-12-18, 05:02 AM
lexusrus
lexusrus's Avatar
X2.
Many times if I'm in the fast lane (two lanes going on the same directions) taking off in M Sports+ mode, I noticed the car to my right tend to go toward the extreme right side and often onto the shoulder as I speed up. I guess the Borla EXHAUST SYSTEM is LOUD and scares people nearby!!! LOL.
Old 05-12-18, 03:20 PM
ct6978
ct6978's Avatar
When you select Sport S+ (vs plain Sport or any other drive setting) there's a sound "enhancing' system that comes on, ASC...try it some time, switch between Sport S and Sport S+, its louder, but its artificially enhanced.
This is different than the intake sound you get when it opens at a higher RPM...
From Lexus press material, by way of Forum member dchar:
The sound blasting from the RC F’s quad stacked tailpipes is sure to turn heads and raise pulse rates. Yet, Lexus also had to design the cabin to be quiet enough to enable enjoyment of the standard premium sound system or sonically stunning Mark Levinson® Premium Surround Sound system.
How could RC F drivers enjoy both? The answer is Active Sound Control (ASC), which lets the driver control enhanced exhaust, intake and mechanical sounds within the cabin. Specifically, Lexus sought to approximate the aural experience provided by the Lexus LFA, which issued some of the most stirring mechanical intake and exhaust notes of any supercar. Although LFA V10 engine revs to 9,000 rpm and RC F’s V8 to 7,100 rpm, the engineers have come close.
An electronic control unit mounted beneath the instrument panel takes input from engine sounds, including varying engine speed, vehicle speed and throttle position and generates augmented sound through an actuator. It is entirely separate from audio system, so there’s no reduction in music fidelity.
Most importantly is the driver controls ASC. It’s activated only in SPORT S+ mode, not Eco, Normal and SPORT S modes. And when it’s on, ASC blends with the natural intake and exhaust sounds to about a 50:50 ratio.
At engine speeds up to 3,000 rpm, ASC issues a steady tone of low and deep sounds.
As revs rise, the tone transforms into a higher-pitched note that blends with the engine’s mechanical sounds, culminating in a free-soaring sound beyond 6,000 rpm.
jcochong37
10-28-15 11:24 AM
Lexalex1
HS 250h Model (2010-2012)
10-06-10 11:50 AM
TokerIS350
Performance
15
06-18-09 11:43 PM
LexusIS-TL
01-26-08 08:41 PM
GS430
04-29-01 01:01 AM
Quick Reply: Turn off the forced induction sound with the rcf?
