Dealer won't honor warranty due to aftermarket exhaust
#61
Just throwing this out there. Hearing people with CEL after exhaust install. Post from way back when, may be relevant. Joe Z is knowledgeable, heck he made a catback for this car. Could be the wires being too twisted on the sensor.
https://www.clublexus.com/forums/rc-...i-exhaust.html
Good luck, got me all scarrred to put on an exhaust now...
#62
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/a42cdf2c_af05_44f0_9591_6570a7a42806_45c71d7b46e6212776a6b6da7f34cfa74cf39a29.jpeg)
Here’s the list of things that the modified exhaust triggered from that code on my car.
I installed my Invidia exhaust and about a month later I got this same exact code. It has to be because of the exhaust. Some days it will go away and some weeks it stays on. 100% your fault and not a factory issue. Take a look at all the possible errors.
#63
GunnyFitz (08-24-18)
#65
I had my Joe Z exhaust installed by my Lexus dealer back in May of 2016 with 10,000 miles on. Now with 31,000 miles no CEL, which is a good thing because in New York we have yearly inspection and with a CEL no inspection ! I did keep my old system just in case.
#66
Were you able to resolve your problem? I also have an Invidia and I'm getting a P0420 code. I changed the crush gaskets already, but the code came back after a few hundred miles. Wondering how did it go for you.
#67
Really odd. I have had my Invidia full catback for 4 months now and it has been nothing, but perfect. Check your installation as it might be a leak somewhere.
#68
Have wonder if those experiencing exhaust CEL didn’t disconnect the O2 sensor under the door sill before removing them from the exhaust resulting in damage to the wiring. I’ve put over 19k mile on the Apexi catback on my RCF without issue.
#69
I ended up installing O2 sensor extenders. That solved the CEL and no impact that I can tell to performance, i.e. 0 - 60 time. It was a oddball kind of issue. Intermittent CEL, much less in the cold weather, much more in hot. And only one side, although I installed the extenders on both.
#70
Thanks for sharing. I was getting ready to take my car to the dealer and have them diagnose/fix the problem even if out of pocket, but the extenders also sound like a viable option. Where did you get them from (any specific part numbers)?
Thanks again!
Thanks again!
#71
^^^ I've had half a dozen or so warranty services on mine over the last 3 years, all of which were with the JoeZ exhaust and probably more than half those with the apexi throttle controller. For the most part all the lexus guys said was how awesome the car sounded - I did have one tech tell me that he thought lexus would deny warranty service on the ECU should it fail because I had installed the throttle controller, but that is the only comment I've had up until now. Still waiting to hear back from the lexus guys on the cat.
#73
gas cap not sealing (CEL), drivers seat lumbar support quit working, the CEL I mentioned in the initial post, they over-filled the oil on the first free oil change. That's all I can remember.
#74
I would advise being careful if you buy O2 bung extenders. If you look at area around the bung, it's a restricted space, not a ton of room. I went with these:
Available on Amazon. I borrowed an O2 sensor wrench from AutoZone, and it was not a difficult job to get these in. Had to do some minimal bending of heat shielding to get them in place where they are not hanging or exposed below the tubes. Problem solved.
Vibrant 11619 J-Style Oxygen Sensor Restrictor Fitting with Adjustable Gas Flow Inserts
RaulTX (08-02-19)
