Lug nut / spacer help
When I got the car I put 15mm spacers on the rear wheels and swapped out the stock lug bolts for extended ones to accommodate the spacers. My lease expires next month and I am trying to find extended lug nuts I can use without having to swap out lug bolts. Can someone please point me in the right direction... I still have stock wheels so I need the same toyota Mag style lug nuts with washers.. Just 15MM longer than stock..
I’m assuming that you’re not willing to swap in the factory length lug bolts. A quick search yielded to this eBay product. They seem longer than factory ones but I can’t find mine to measure and compare to the 1.87 length description of these ones. Worst case, I would turn those factory lug nuts you still have into open lug nuts, just not sure how that would play out with the dealer.
https://m.ebay.com/itm/24-TOYOTA-OEM...=Make%3AToyota
I saw those. If I cant get anything concrete from someone this week I'm just going to order them and see if they work..
ScBouncE
SC- 1st Gen (1992-2000)
01-27-14 06:58 AM
stvincent
Wheels, Tires & Brakes Forum
10-18-08 04:51 PM
