Do I need new rotors if I am replacing brake pads?
Hey guys
do I need to replace my rotors if my brake pads are being replaced? My car has around 16k miles. If so, can you guys recommend some good brake pads and rotors. I was thinking of project mu ns and I don't know about the rotors.
thanks guys!
thanks guys!
The rotors will need to be measured (thickness) to determine if they need replacing. The measurements are usually cast into the rotor somewhere. The other consideration is if your rotors require machining.
Sometimes though, yes you can just slap on new pads and off you go, but the glaze on the rotors should be scuffed up to help bed in the new pads.
^^^^Rotors should never be machined (turned). If they are grooved replace them. If there is pad deposits, whey can be gently sanded off. Thickness measurements, as mentioned, need to be done to determine when to replace. Proper bedding of the new pads is of utmost importance.
Lou
Lou
Opnion
In my "personal" opinion, I'd say NO. Unless you're experiencing any type of shudder or braking difficulty Pads alone is fine.
Heck, I'm seeking for new pads right now that wont produce the ridiculous amount of Brake Dust these OEM Pads do!
In theory you lose a small amount of stopping performance, but reduces dust and noise, at no cost to you if you qualify.
Here's a thread with the bulletin, check post #46:
https://www.clublexus.com/forums/rc-...em-pads-2.html
My Bad
There's a service bulletin that will have the dealer replace your original pads (assuming this hasn't already happened) with ones that don't put out as much dust and won't squeal during low speed braking.
May as well ask you here, as I was just offered a pretty good deal on replacement pads. Let me know if any of this is both legit and what I seek...
(NOT Tracking whatsoever!)
"Those Endless MX72 are phenomenal pads but aggressive. - If you're just street driving the car with no track use then the new Project Mu PS compound or the Carbotech 1521 compound will be the best option for you. .....the new Project Mu compound is better as opposed to the Carbtoech pads because the quality control is a bit better with those. ...Carbotech has again increased the price because there have been so many issues
...List price on the Project Mu PS compound is $486 for the front and $281 for the rears."
Esseintially than- Is Carbotech or Project Mu a better choice? (Sorry "Spam" I didn't mean to Hijack your thread!)
PS. Thanks again and here is that TSB if anyone needs it. (Sure is an Old One though huh?)
Keep in mind, there is a trade off. The OEM pads the car comes with, are high friction pads that give the best stopping power under heavy use. While the TSB pads would have less squeals and dust, the stopping power will not nearly be as good. Some people say, if you don't track the car, it is not an issue, but for others like me, I choose to stick with what originally was designed for the car.
Yeah, I was just comparing OEM and TSB pads. There is a trade-off there. The TSB pads while having less dust, don't have as good a stopping power as the OEM brakes especially repeated heavy braking.
Its A Dust Issue
OEM - SHOW-EM = The Dust is CRAZY Rolla!
I just want these things GONE. Spoken w Speed Freak on these "Alternatives" Lou is talking about.
I'll wait until my first Service at 5k miles, or come late Sept when I swap out my Bling Wheels with Stock for a 12 hr drive. One deep a** pothole and these suckers will end up crooked as the Administration!
Are 2016, and later year RCF's, still coming from the factory with brake pads that may give excessive squeal and dust?
McMuffin
10-10-08 11:12 AM
