Any 2017 rcf lowered on coils?
Old 08-01-18 | 06:05 PM
Spam89's Avatar
Spam89
Default Any 2017 rcf lowered on coils?
Want to lower the car but wanted to know if anyone with a 2017 Rcf had ride issues!
Old 08-01-18 | 07:18 PM
Ricardorc's Avatar
Ricardorc
I am lowered on Swift Springs and avs , I don’t think they have any coil overs available due to the avs
the car rides like stock my car is a 17
Meraki Autoworks (08-02-18)
Old 08-01-18 | 07:47 PM
Spam89's Avatar
Spam89
Damn I know about our current situation but does the springs really cause faster wear?
Old 08-01-18 | 08:43 PM
05RollaXRS's Avatar
05RollaXRS
Depends on the type of springs you get. If the spring rating is high enough, it will not cause premature wear on the dampers. However, if get soft springs like the RSR super downs (significantly softer than the swift springs) then it will wear out your dampers quicker. Swift springs are quite decent as far as spring rates go.
Old 08-01-18 | 08:44 PM
Ricardorc's Avatar
Ricardorc
No issues here brotha! I’ve had them for 3 k
evertything going well so far
Old 08-01-18 | 08:59 PM
Spam89's Avatar
Spam89
Thanks I currently have 19 inch wheels and the rear gap is a lot better the the front so want to drop the front a bit more. Keep in mind I am riding on stock suspension. If I lower just the front, would it deter the car's performance or cause more wear on the front suspension?
Here is my current ride. Should I stay stock or do you think getting springs will make the car / wheels pop more. I am a newbie in nodding car's so all the help would be great!
Old 08-01-18 | 09:08 PM
05RollaXRS's Avatar
05RollaXRS
I would say, in order to keep the car predictable and consistent, you want to put swift springs both front back. Your rear will have minimal drop anyway. Having a different spring rate front and back could make the car unpredictable or even dangerous especially when you are pushing it hard into, through and out of the corner. The front and back compression/rebound is impacted by how the spring compresses. Springs typically drop more on the front anyway compared to rear. I believe swift has about 1 inch drop on the front and 0.8 inch on the rear.
I also notice the same thing. The rear end is absolutely perfect as there is barely any space stock. However, the front has about 2 inch gap, but I am sticking with the stock suspension despite the monster front space being an eye sore.
You can see, I have the same dilemma. Front has about a 2 inch gap while the rear barely 1 inch
Limelight (09-04-18)
Old 08-02-18 | 10:12 AM
theman's Avatar
theman
totally agree with Rolla, match set springs front and rear for sure...
Old 08-02-18 | 10:49 AM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
We have the Swift Springs in stock!
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 09-01-18 | 10:13 AM
GunnyFitz's Avatar
GunnyFitz
Default Yes!!
This is exactly what Im seeking to do next! Not jacking w suspension or rears, just want that drop up front. Also, shop told me they usually bring you back in like 300 miles for doing an alignment. Sound right?
RSR will most likely be my choice. Then again my dumba** doesnt know any different anyway.
Know Labor Rates differ but what are most folks seeing for front end mount times?
Thanks for asking the question on our 2017s!
Old 09-01-18 | 11:42 AM
05RollaXRS's Avatar
05RollaXRS
Yes, you need alignment once the springs set-in properly. I did that on my other car where I put Megan Racing springs and then alignment after 500 km (about 300 miles).
I would steer clear of RSR super downs because they are soft springs. Your shocks will work hard to keep up with the spring pogo'ing up and down with soft spring rates. That will lead to premature failure of your shocks (it happened for at least one member on this board). Go with swift spring as they have significantly higher spring rates than super downs and will work better with the stock shocks. Also, your adaptive shocks are very expensive because they are electronic. Trust me, you don't want to blow them up as it will be a costly replacement.
Old 09-01-18 | 01:12 PM
GunnyFitz's Avatar
GunnyFitz
Default WoW
Damn Rolla. You right, again! Ill be hitting you up fo sure brother. Thanks. TBD.......
stephenmat
03-08-18 11:02 AM
bigwes
Suspension and Brakes
13
12-05-12 08:11 PM
Wheels Boutique
09-10-02 11:21 PM
pot_head
05-24-02 01:26 AM
Quick Reply: Any 2017 rcf lowered on coils?
