Navigation SD Card Part Number
Can anyone pop their navigation SD card out and send me the numbers on the back? Should be something like 86271-XXXXX with a sub-number of XXXX. My little guy took my card out and lost it somewhere so I've got to track down another one, wanted to make sure I get the right thing.
I've read multiple things about not being able to move SD cards between cars, but some people have and it worked. I'm assuming this is more about the card being for a particular navigation generation and car then it being locked to a vehicle. Anyone have any information on this? I really don't want to cough up $200 to lexus just so my navigation stops saying "Unable to read Data" would much rather scoop up a used one for $40 off ebay since I use my phone for navigation anyway.
Thanks everyone!
Thanks everyone!
What are you talking about???
Thanks everyone!
Thanks everyone!
Under the heater control panel is a little door that has a bunch of logos on it like the Dolby DTS logo etc. If you flip it down inside there is a SD Card that contains all the maps for the nav unit. My kid found that little door and thought it would be cool to pop out the SD card and then go lose it somewhere. I'm looking for a replacement one so I was just hoping someone could pop their card out and flip it over, there should be a set of part numbers on it so I can make sure I get the right one.
So you want my SD card's serial numbers??
SAY WHAT!!!
If I DID give IT to you, wouldn't mine be USELESS AFTERWARDS since each SD card is "married" to each HEAD UNIT?
SAY WHAT!!!
It's the part number, not the serial number, all of them are the same. No different then giving me the part number off your fender would render it useless. The SD card isn't "married" to the head unit so far as my research has shown, if it does get tied to the head unit it happens when you initially install the SD card so you'd need to have it physically in your possession AND it would have to have not been used on another vehicle previously.
detinater (08-09-18)
here's one on for 54$ shipped:
https://www.ebay.com/itm/16-17-100-G....c100005.m1851
Thanks for taking the time pull the numbers for me.
Pull card out. Image card to new card. Test.
I bet it works.
The head unit probably serializes the software on the card which then prevents other head units from using it. Also sounds easy to crack.
I bet it works.
Has anyone been successful with this?
I think the OP had list the SD card bc his kid was playing around in the car and is now the SD card is missing. Therefore he doesn't have the SD card to copy and "image the card".
cwonglex
NX - 1st Gen (2015-2021)
01-10-19 07:56 PM
