RC-F, questions about suspension and wheels
I have found one to purchase from a dealer. I'm driving 3.5 hours away tomorrow to finalize the deal if the car checks out ok. The car has Vossen VFS-6 20" wheels, I believe 255/35/20 and 285/30/20's if I remember correctly. With RS-R springs, Manager tells me the front tires rub at slow parking lot turns on the inner fender. Is this common with this set?
Here is the car...
http://www.maseratiofjacksonville.co...499ed20731.htm
Here is the car...
slper (10-13-18)
I would avoid it with RS-R springs. RS-R spring rates are soft on those springs. Swift springs are much better. Probably the shocks already have aged a lot since softer springs make the shocks work harder.
Looks like you don’t have to worry about an exhaust upgrade for now atleast . Already upgraded . Also noticed it has all the packages so it’s a good deal for sure, you can always change the wheels as that rubbing tends to get pretty annoying.
Go for it ✌️
Go for it ✌️
I said, must be aging faster because soft springs make the shocks work harder. Also, there are implications in handling dynamics. I have personal experience since back 7 years ago, I blew two shocks on soft H-Techs.
Speaking of bad shocks, CorradoMR2 blew both of his front shocks at less than 10,000 miles. He had RS-R super downs. You can find his thread, if you search for it.
There are many very good coil over options available for the RCF like the Penske from RR racing. Also, swift springs are matched well with stock suspension.
My RCF is bone stock and has 10,000 miles. I will keep the suspension pretty much stock and put bolt-ons like full exhaust, throttle controller etc. Also, switch to much more aggressive tires like the MPS4S. Have to figure out, if tires are going to be first or exhaust next spring.
slper (10-13-18)
Here is the thread from CorradoMR2. I searched for it so that you can read through it
https://www.clublexus.com/forums/rc-...ks-anyone.html
slper (10-13-18)
MKIV98TT
17
06-04-13 12:18 PM
