New Wheels for 2019 Lexus RCF
GunnyFitz (04-30-19)
Hello,
We offer a huge variety of wheels from forged wheels to flow forged wheels.
Depends on what you're going after.
Feel free to contact us !
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
GunnyFitz (11-15-18)
Signature Wheels!!
-Josh
-Josh
__________________
Orange County, CA
Orange County, CA
I just fitted the BC Forged HCS04S....just another option for your consideration
Specs:
F: 20x9.5 et 40 w/ 265/30R20 @ -1° degree
R: 20x10.5 et 35 w/ 295/30R20 @ -3° degree
S: Swift Spec R + SPM adjustable camber arms (rear)
Specs:
How much adjustment did you need in the rear to get the camber in spec? Just wondering how necessary it is to add the camber arms. If I lower mine, I would go coilovers and drop the rear about half as much as lowering spring.
Wheels look great. I love the 2pc with exposed hardware. Looks like you could have a little more offset up front. The 265/30 looks great on the 9.5, glad it worked out.
As for the rear, I'm not sure how much adjustment the factory setup will allow. We initially started with 2° neg (with adj. arms) but increased it to 3° neg for the same reasons mentioned above (more clearance). From all accounts on the interwebs the adj. arms are not a necessity but more of a safety net. Keep in mind that camber increases naturally when you lower the car.
In the big scheme of things I guess my setup would still be considered conservative - this was deliberate as I do enjoy the odd run through the hills so didn't want to worry about ripping guards out etc. The fronts could run a bit more offset if you were keen - keep in mind that there is a protruding mounting tab and screw that attaches the side vent to the inner front guard, this will have to be modified. Even in my case I'm going to have it modified altered from a horizontal mount to a vertical to increase clearance.
