Battery Size
Battery Size
Does anyone know the size of the rcf battery. Ive seen on the forums that it uses a size 34, however the gsf and isf use a size 24. Just want to make sure beforehand.
https://shop.advanceautoparts.com/fi...s-rc-f-battery
or Use the battery finder at Interstate:
https://www.interstatebatteries.com/
^^^^I saw that, and ignored it. That's a size I never heard of and certainly is not a standard battery size in the US:
https://www.jegs.com/Sizecharts/bcigroup.html
From my experience with Lexus, I have found that they all take either a Group 24 or 24F, depending on what side the stock battery is located. Both batteries are the same size but with different polarities. Batteries mounted on the left (passenger side) a Group 24, on the right a Group 24F.
Edit - Looks like I was wrong! I did further searching and came up with this:
Lou
Lou
I put an Optima 25 in mine. I used a piece of rubber to clamp it down as it was a bit low. Works great and saved some weight.
FWIW: THE CORRECT BATTERY SIZE IS H6R.
For people searching for this on the run (like I had to after a battery died while in a parking lot) the 24/24f is *not* the right size. I bought one and tried.
You need to find a H6R for the battery to fit into the plastic battery surround correctly. An H6 is the correct size, but the terminals will be on the incorrect side.
I replaced the H6R when it was dying with a duralast group 34 AGM. Not exactly the same size but fits good enough to not have to change anything. More CCAs. About the same weight, tho.
Mingofish (08-25-19)
BossMoss (10-18-19)
RCF battery info.
Group size H6/H6R:
ba2sy (03-28-20)
Tech Info Resource
ba2sy (03-28-20)
ba2sy (03-28-20)
pfff who needs a battery... good ol' crank start is the best
