MARK LEVINSON® PACKAGE - Reorder/delete preset stations
Hi, I hope this is the right place for this...
2019 RC F... how do I reorder my preset radio stations? Or delete a station? I asked the tech specialist at the dealer, she hesitated, and said you can't do it.
Wow.
Thanks.
Wow.
Thanks.
![Wiggle](https://www.clublexus.com/forums/images/smilies/wiggle.gif)
Thanks for this. My other car, a buick, brings-up a reorder screen where you can drag and drop station icons to reorder or just click on one to delete. This screen is tucked away in the menu system so I thought there might be a similar one in the RC F.
The Owners Manual has specific sections for this - even a Quick Guide on how to operate the whole system.
Thanks for this too. I have pretty much read these, at least the multimedia section. I couldn't find an easy way to do as I ask above, and thinking I was just overlooking something. I will explore further.
You simply save over each one.... I've done this a few times when shuffling presets. If you do this right, you can avoid searching too much, just select one that's in the wrong place, then go to where you want it, click and hold till it writes in that spot, then repeat until done. I've also used the setting that controls how many presets are shown (I usually use less than the max) to display more temporarily, use those to save some while I work.
