I brought the car used with MPSS, therefore the tires had over 10,000 miles. Here's my observant:
Ride- very stiff (I would see the bump on the road and wait to feel it) the ride was so bad I would dread taking a road home that has a considerable number of imperfections......the car road like a 2016 Camaro SS
Noise- LOUD and EXTRA LOUD over coarse interstate pavings
Traction- little to none...I could spend the rears and wheel hope anytime during take off and in turns
Tramming- none
Steering- tight, stiff, and like a GS F-sport in sport plus mode, and similar to an Acura Type S
The Michelin Pilot Sport A/S 3+ observation:
Ride- Transformed into a smooth riding LEXUS...... rides like the GS Fsport and RC Fsport
Noise- quiet, normal, and surprisingly good while on the interstate
Traction- Amazing....with 1st gear pulls, I haven't spent the rear tires in the dry (32 degrees) or on wet roads (65 degrees)......also no slipping while truning
Tramming-none
Steering-Transformed into being light and easy to drive at low speeds or while parking....quick at high speeds
Michelin Pilot Sport A/S 3+ tires and Borla.....
have transformed this car from a firm riding V8 Lexus into a fun to drive dream Lexus
My Michelin Pilot Sport A/S 3+ REAR tires is almost gone....it's almost to the wear indicator bars.... Front ones are still "new looking".
I feel it sliding, especially in heavy rain. So I've already bought two rears to replace.
Tramming- none
Tramming-none
Very odd you find the stock MPSS tires very stiff. Mine have roughly 10,000 miles as well, but I find them to be "mushy" especially with the super soft sidewalls. I hate the side-to-side shift leaning over the sidewalls. I am actually going for a stiffer setup with the XL-rated (reinforced sidewalls) MPS4S for my next tires. Anyway, glad you like A/S 3+.
I also run the A/S 3+ because I spend a lot of time out of south Florida. In colder temps the summer tires grip is terrible, while I notice almost no difference in grip from the all seasons in 30 degree temps vs higher temps. I also notice a lot better grip in the rain from the all seasons. Which is nice even in south Florida because it rains a lot.
I also find it curious that the all seasons are described as having more grip. I wonder if the previous summer tires were properly warmed up? Out of the garage first thing in the morning they will slip a bit if you jump on it too soon. They are performance summer tires of course and need a bit of heat. You literally cannot drive MPSS all year unless you live somewhere that never goes below 40ish. I don't go out under 45degrees myself.
My plan, like rolla, is to move to the MPS4S once I find a deal as it's starting to warm up and I'm itching to drive the car after a long winter in the Honda.
My guess is, All-season tires have softer compound so it adheres better to dynamic load changes over the contact patch better than a stiffer summer tire, which bends/deforms a lot less so it will tend to "glide" over the surface rather than "digging in".
I have the same tires as well. They looked like almost brand new 3 weeks ago when I bought the car. I've never owned a set of Michelin's before, but I know their reputation. I looked at the traction wear rating at 500, and thought. These things are going to suck at the road course! But Ill have to say, I was really surprised at the performance they put out. They seemed to perform like a 200 or
less traction wear tire. They also scrubbed off the sides of the front tires pretty bad. Im actually glad I only ran on Sat due to rain on Sunday. I think Id be having to replace the fronts asap.
^^^^I would not replace the AS +3 tires on the front and leave the rears alone. Hi-Po Summer tires have very different handling characteristics and rubber compounds than All Season tires. You may get into trouble, especially on a track. Just my opinion.
3m wrap simply glows at night... had to show you rear....still shine after a rain drive this tire should have been an option....
Wow, I didn't realize so many of you guys roll with the A/S 3+...... I was really on the fence about getting MPS4S and after reading a report from Michelin about running summer tires in cold weather, my mind was made to pass on them (I do love how they look). Also, I drive my F everyday no matter the weather and wanted it to be safe here in North Georgia.
LEXUSRUS I have a question......How many miles on those rear tires?
We've already burned through a set of A/S3+ on the GS F. Right front was chunking outer tread blocks, and this is the wife's daily that I never push because I always have the kids when I am driving it. I bought another set of them because they work just fine for what we need the car to do, but to say the A/S 3+ has better grip than the OEM tires is not even close to my experience as long as the outside temperature is above 45F. Under 45F, the summer tires are stiff and slide a lot easier than the A/S 3+, but once it warms even a little, the summer tires are head and shoulders better. Truth be told, I have A/S 3+ on my OEM '08 IS F wheels right now because the summer tires are so chattery in winter, even in Georgia. Once high temperatures get consistently in the 70's, the 2014 wheels with PS4S will be back on until late October/early November.
I have put on about 24K miles on the Michelin Pilot Sport AS 3 Plus rears. But I had up sized to 285/35 R19 103Y XL BSW
Now the rears are ALMOST at the wear indicator bars. When new these were GREAT on wet cold below 40 and above 32 degrees F. But now I DO feel it slide in the rain. Will change to the new identical new replacements this week or next I have sitting around.
I noticed (EVEN NEW) these DO NOT have the same grips in DRY HOT weather as the OEM tires that we're on the RCF. But I needed AS for where my RCF is located during the winter months. So I went for the AS3+
I guess 24K miles on the rears is reasonable...... I wonder how the "mileage warranty" works on the staggered setup?
