2020 RC-F Launch Mode
Just Wow!
1. Stop the vehicle.
2. Firmly and fully depress the brake pedal with your left foot. Continue depressing the brake pedal.
3. Shift the shift lever to D.
4. Select SPORT S+ mode.
5. Press the switch.
The “EXPERT” indicator will come on together with the “TRAC OFF” and VSC OFF indicators.
6. Press the “LAUNCH” switch.
The “LAUNCH” indicator will illuminate.
7. Firmly and fully depress the accelerator pedal.
The control standby state will be entered and the engine speed will be automatically maintained between 1500-2000 rpm.
If the “LAUNCH” indicator turns off,
release the accelerator pedal and perform
this procedure again from 6.
8. Within 3 seconds of depressing the accelerator pedal, release the brake pedal to start off.
The “LAUNCH” indicator will turn off 3 seconds after the accelerator pedal is depressed.
If the brake pedal is not released before the “LAUNCH” indicator turns off, release the accelerator pedal and perform this procedure again from 6.
After starting off, when the accelerator
pedal is released, launch control will stop
operating.
WARNING
■Launch control precautions
Observe the following precautions.
Failure to do so may result in death or
serious injury.
●Do not use on public roads.
●Use only when road and ambient conditions
are safe.
●Before use, ensure that no people or
obstructions are nearby.
●Proper use of launch control requires
an expert level of driving skill. When
using launch control, always check the
track conditions and surrounding area.
●Do not start off with the rear wheels
spinning.
operating.
WARNING
serious injury.
are safe.
spinning.
DANG! Thats awesome! Wish all the RC's had LC....
