Present and Future Modification List
Old 05-13-19, 07:21 PM
BlueRCF10
BlueRCF10's Avatar
Originally Posted by Apone
man I really do like the new tail light design.
Beauty! I agree!
Old 05-14-19, 04:25 AM
BlueRCF10
BlueRCF10's Avatar
Originally Posted by konichiwa3
Present mods
  1. RR racing Ultimate Steering Response Lower Control Arm bushing
  2. RR racing DA Penske coilovers
  3. Racing Brake 2 Piece Rotors Front and rear
  4. Racing Brake XT970 brake pads front, XT910 brake pads rear.
  5. Michelin PS4S tires
  6. H&R Wheel Spacers 15MM rears only
  7. aFe oiled Air Filter
  8. RR racing Silicone Radiator hoses
  9. Denso Iridium Racing Spark Plugs
  10. Braille ML30C Lithium Battery (to be installed shortly)
  11. Aluminum mount kit
Future mods
  1. ARH long tube exhaust system with the headers coated glacier black Cerakote
  2. RR racing or Figs Engine mount
  3. Titanium axleback exhaust muffler (not sure brand yet)
  4. Ohlins TTX coilover to replace the Penske
  5. HRE lightweight wheels
  6. Racing brake Carbon Ceramic Front rotors. (Potentially)
At what mileage did you do the spark plugs? Did you notice any difference?
Old 05-14-19, 11:09 AM
konichiwa3
konichiwa3's Avatar
Will let you know tomorrow, actual install is happening then. Mileage is 65K. Part of the recommended service for 60K is spark plug replacement.
Old 05-14-19, 12:24 PM
Apone
Apone's Avatar
I went with the one for IS350. The hub bore size is identical on the RCF of 60.1. It is an improvement in every way. I did it mostly to make the car use less sidewall since our MPSS have very soft sidewalls. It definitely did make a difference at slow speeds. Longer term is to get more aggressive tires since I don't care much for ride comfort as it is not my daily driver.
Any downside here Rolla? I recall a convo between you and lubouxracer I think about spacers. I like the way it looks but want to consider any implications as it must change suspension geometry. Especially at 20mm vs something less aggressive.
Old 05-14-19, 12:32 PM
BlueRCF10
BlueRCF10's Avatar
I need to install my spacers. I got 20mm in the front and 15mm for the rear.
Old 05-14-19, 12:35 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,484 Likes on 1,788 Posts
Nope. My personal experience of over 1 year are very positive. No downsides. I will get the first alignment done at the dealership next week so I will see what the numbers are. Car feels very stable and tends roll less over the sidewalls (which is what I wanted as a workaround till I change the tires). This is mostly because of the center of the contact patch gets pushed slightly out so the cornering downward forces directly line with the center rather than the sidewall. Steering feel/weight does not change much. Just have to be careful on tight roads with curbs etc. Just have to make sure they are torqued properly and the wheels are torqued properly as well. I use 80 ft-lbs.
Apone (05-14-19)
Old 05-14-19, 01:12 PM
Apone
Apone's Avatar
Thanks - it looks great
05RollaXRS (05-15-19)
Old 05-14-19, 01:17 PM
05RollaXRS
05RollaXRS's Avatar
One thing I see a clear difference is when the shift shock happens at redline/rev limiter (manual/sport+), without the spacers, rear tires used to get unsettled, but with the spacers on it kicks harder in the back of the seat without any movement in the chassis/rear suspension. I put 38R/36F to keep the rear as solid as as brick while allowing some front roll under cornering to make the front end bite/grip. I don't doubt there might be some negatives of spacers, but in my experience, I have not seen any yet. I will look at the alignment before/after next week. Knock on wood!
Apone (05-14-19)
Old 05-15-19, 09:42 PM
konichiwa3
konichiwa3's Avatar
Installation done. Haven't done enough sit time with car but my first impression is the car is different.
The most surprising thing was the engine sound. Once my Indy installed the spark plugs his first comment was the engine sounds different and he picked up on that instantly, I thought to myself "you got to be crazy". Sure enough the minute I jumped on the freeway the engine sound was a lot more pronounced and deeper. Very unexpected!
At high rpm the car seemed to pull a lot faster in a very strange way. I need to do more sit time and report back but certainly car is bizarrely different.
According to Denso their tests showed increases in HP 10 to 15HP but I took that with a grain of salt but now I'm beginning to wonder if that really is the case.
My Indy also commented he has never in his profession seen a spark plug with such a tiny center electrode. He's installed a couple HKS racing plugs but stated those have had issues with throwing check engine lights.
Old 05-16-19, 05:18 AM
Mingofish
Mingofish's Avatar
koni
was the plugs a different range? Or oem spec?
Old 05-16-19, 07:07 AM
luislopezt
luislopezt's Avatar
Konichiwa3,
part # for the plugs?
Old 05-16-19, 06:59 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,025 Likes on 2,439 Posts
Denso recommends IKBH20TT, but those are not racing plugs. Probably IKH01-24. A little cold, but not horribly cold. I wouldn't expect a super long service life with these plugs, but making more power is intriguing. I've never had that be true except when the ignition system was less than stellar and a better plug made up the difference in getting a decent spark.
Old 05-16-19, 08:51 PM
Mingofish
Mingofish's Avatar
Lance,
colder?
Old 05-16-19, 09:01 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Originally Posted by Mingofish
Lance,
colder?
The bigger the number on a Denso plug, the colder it is. Racing plugs are typically colder than street plugs because they're expected to run at a higher load than the average street driver, and the likelihood of carbon fouling under racing conditions is much smaller. The second link is the manual with all the information about Denso plugs of all kinds. Worth a read if you haven't learned a whole lot about spark plugs. The manufacturers are pretty awesome at providing solid technical information to the public unlike a lot of other industries.
https://www.denso.com/global/en/prod...sic/heatrange/
DENSO_TM_H1H4 - t-manual.pdf
The following 2 users liked this post by lobuxracer:
Apone (05-17-19), luislopezt (05-17-19)
Old 05-16-19, 11:30 PM
konichiwa3
konichiwa3's Avatar
Sorry guys for the late follow up but lobuxracer has got you all covered. His information is spot on.
Yes, they are colder. Stock is 20, this are 24 hence the part number IKH01-24. They fall nicely in the middle between a hot plug of 16 and a cold one of 31.
I wouldn't be worried about fouling this colder plugs as IMO RCF engine runs pretty darn hot, also this particular spark plug has Denso's patented spark cleaning pocket technology to burn off any carbon deposits.
Got more time with the car today. Definitely the car is accelerating noticeably harder. The character of the car has changed, the rev climbs a lot quicker between the mid to high rpm. My thoughts are combustion is highly efficient at the high RPM's with this spark plug, producing more power.
The deeper sound of the engine is still there and it's unmistakable.
They are a lot pricier and just as lobuxracer stated, shorter life span. Service interval is 30K as opposed to 60k for OEM.
All I can say is I'm very pleased with how all this turned out.
And the cherry on the cake I expect better MPG.
Below are a couple of links for those interested. You can thank me later as this was weeks and weeks of research since this Spark Plugs have never been discussed on the RCF platform yet it turns out it's quite a favorite among engine tuners.
Denso
http://densoautoparts.com/Portals/De...m-brochure.pdf
http://densoautoparts.com/spark-plug...aspx#undefined
http://densoautoparts.com/iridium-ra...lug-components
TRD
https://www.trdparts.jp/english/parts_plug-racing.html
Where to purchase along with specific part #
https://www.amazon.com/gp/product/B000M6XOQ4/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000M6XOQ4/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Excellent info by Brisk about heat range
https://www.briskusa.com/spark_plug_...at_range_chart
The following 6 users liked this post by konichiwa3:
Apone (05-17-19), CAHWY128 (05-17-19), lobuxracer (05-17-19), luislopezt (05-17-19), MileHIFcar (07-08-19), Mingofish (05-17-19) and 1 others liked this post. (Show less...)
Quick Reply: Present and Future Modification List
