2015 RCF Long Start
Old 05-17-19, 08:44 PM
Alexaja
Alexaja's Avatar
Default 2015 RCF Long Start
Has anyone had trouble with a long start on their RCF? It started about a week ago. It's taking about 3 to 4 seconds on a cold start. I tried running a couple tanks with injector cleaner...hasn't helped yet. I did read something about changing out the battery. Not sure because it has a good charge. Any suggestions?????
Old 05-17-19, 09:10 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,470 Likes on 1,775 Posts
How many miles? Probably your spark plugs need to be replaced at high mileage? Mine has 10,000 miles on it and this is how it starts:
Old 05-17-19, 09:26 PM
Alexaja
Alexaja's Avatar
It has 60k. Plugs really shouldn’t need to be changed until a little later right.
Old 05-17-19, 09:27 PM
sensai
sensai's Avatar
I'm at ~15,000 and same start for me as 05RollaXRS
Old 05-17-19, 09:33 PM
1BAD4DR
1BAD4DR's Avatar
Battery is probably failing
Apone (05-18-19)
Old 05-17-19, 09:35 PM
1BAD4DR
1BAD4DR's Avatar
Lexus can test the battery to see if it’s good or not. I noticed the first time my card was hard to start told them during my oil change visit they tested the battery and it failed. Replaced under warranty.
Old 05-18-19, 05:17 AM
Apone
Apone's Avatar
Mine had this after sitting, I'm betting battery.
Old 05-18-19, 06:05 AM
CAHWY128
CAHWY128's Avatar
I may be wrong but I think I saw somewhere 60K for plugs.
I will probably do mine around 30K, but I am a maintenance weirdo...lol.
Old 05-18-19, 06:54 AM
e2dag
e2dag's Avatar
Maintenance manual suggests replacing them at 60k miles.
Old 05-18-19, 07:04 AM
GunnyFitz
GunnyFitz's Avatar
Default Sweet!
HMine has 10,000 miles on it and this is how it starts:
https://www.youtube.com/watch?v=buOy7ENzLaY
Dude!! Once again, that sounds absolutely fantastic Rolla!!
Wise choice other than the Armytrix system you initially wanted. Your Invidia was my 2nd choice for sure! Love it man!
*Tried loading my cold start but keep getting error msgs*
05RollaXRS (05-18-19)
Old 05-18-19, 09:55 AM
flowrider
flowrider's Avatar
Received 1,899 Likes on 1,340 Posts
No - Your plugs are due for changing. Read your manual.
Lou
The following 2 users liked this post by flowrider:
05RollaXRS (05-18-19), lobuxracer (05-18-19)
Old 05-18-19, 10:48 AM
05RollaXRS
05RollaXRS's Avatar
Thanks man.
Old 05-18-19, 01:48 PM
slper
slper's Avatar
Starter isn't spinning fast enough from a weak battery. You would see and feel if your plugs were bad. You would see bad fuel mileage, feel it in the sit of your pants, poor performance. Have dealer or parts store perform a load test on the battery.
Old 05-18-19, 10:34 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,964 Likes on 2,401 Posts
This does not reflect my experience with worn out plugs. A battery load test is prudent, but your plugs are at the recommended change interval. I would start there if for no other reason than they are due for replacement under normal operating conditions.
Downtuned
09-08-15 08:50 AM
koaishi
Maintenance
09-21-12 01:58 PM
LudeNsoL
03-06-12 08:24 AM
Bigrahizzl
Maintenance
05-25-11 09:02 PM
1genls400
05-17-08 05:21 PM
Quick Reply: 2015 RCF Long Start
