DIY Rear Bumper Reflector Upgrade with LED Lights (CROSS POST)
I accidentally posted this on the normal RC forum, and hate to dupliate the thread, but thought that some people might not see it so here's the Link to the DIY for Rear Bumper Reflector LED light upgrade on my RCF!
https://www.clublexus.com/forums/rc-...ed-lights.html
I hope this helps some people out!
Mingofish (06-23-19)
FYI, the website shows the same reflector used, so no worries there. Also fits a few RX and mini vans too haha.
Installed mine last week, I have the sequential version, wired up a harness so that I can disconnect my bumper easily; just two harness: 1. factory parking sensors and 2. bumper lights. I recommend you solder the wires to the OEM plug sockets, T-Clamps or such might be an issue due to limited space, FYI.
Raerae had a good write up, I did a few minor changes but here is my wiring diagram if you have a sequential action or if you have standard LED version but want it to flash with turn signal/hazards:
1. I bought 18/4 wire male/female connectors that are water tight for quick disconnect and mounted it right next to the parking sensor disconnect.
2. bought 18/4 wire, single sheath, and soldered both ends.
3. ran a single 18ga wire from right signal bulb (green/white wire) to the driver side safely and out the quarter panel grommet.
4. I did not use the bumper LED 'white' wire because I did not want them on unless I was either braking or turn signal.
raerae1616
RC - 1st Gen (2015-present)
14
01-27-20 12:04 PM
