I wrapped my rcf
Old 12-30-19, 01:25 PM
diggdyone
diggdyone's Avatar
Default I wrapped my rcf
5 days later my RCF is wrapped in Avery GLOSS CARMINE RED. I did this for less than $600! For comparisons I paid $450 for my GS350 roof, wing and front bumper to be wrapped.
I did it and SO CAN YOU! If you do it yourself the tools are your receipt.....lol
SHOUT OUT to CK WRAP on Youtube.
.. this guy was my motivation and teacher
I have so much info to share........
Please take it easy on me, I love this CLUB and learned much from coming here and only want to give back.
hood and fenders done ...I wrapped under the vent/rocker, because I was keeping the wrap on the side vent
same on both sides
here is 2 of the three (QUARTER, DOOR, & driver ROCKER) pieces I cut from the pass. side....note the rolled wrap on the hood is for the driver side rocker....SHOUT OUT to my son for holding the pass. side for me to cut!
I wrapped the top of the trunk 1st ...You can see me using the trunk to hold the paper before cutting the driver sides 3pc
here I measured, marked and measured before cutting the DOOR, QUARTER, AND THE PASS. ROCKER...I started the cut high in the back due to the rear bumper stating at the same hight as the side vents...see the monkey tape shows the end of the bumper and quarter
Monkey tape and 6 magnets was my helper ...holding the paper off the floor
if you look close ....the paper for the pass rocker is sized up before laying ......this is how much wrap I cut from the bottom on the driver side starting from the rear...
rocker paper for the driver side is on the hood and the pass. rocker paper is on the car
rocker paper
lil nudity for you all....lol
keep as much as you can in the car
front done
more nudes
I used the ramps to hold the bumper as I took it off....found a how to on the CLUB
Popular Reply
12-30-19, 01:32 PM
diggdyone
diggdyone's Avatar
Default more
DAY 1 .....let it cook in the sun
Butt Pic
Old 12-30-19, 01:32 PM
diggdyone
diggdyone's Avatar
Default more
Butt Pic
The following 11 users liked this post by diggdyone:
1wacko (12-31-19), BossMoss (12-31-19), CAHWY128 (12-30-19), DaveGS4 (12-30-19), jonmonkey (01-07-20), JT2MA71 (01-01-20), MCB1970 (01-02-20), Mingofish (12-30-19), plex (12-31-19), rp2000r (12-30-19), SoSlow (12-30-19) and 6 others liked this post. (Show less...)
Old 12-30-19, 01:46 PM
chris07is
chris07is's Avatar
Default Nice
Looks awesome man... mad skills...
Old 12-30-19, 02:27 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,475 Likes on 1,780 Posts
Looks great. Super bright red.
Old 12-30-19, 03:25 PM
vbb
vbb's Avatar
Wow, great job! That looks far beyond a home garage DIY job.
My only criticism would be that the orange calipers clash now. They'd look better black to match your theme, though I understand why you wouldn't want to paint them.
BossMoss (12-31-19)
Old 12-30-19, 03:39 PM
diggdyone
diggdyone's Avatar
Thanks for the complement....as for as the calipers they are wrapped too....Black is the factory color and yellow maybe next
BossMoss (12-31-19)
Old 12-30-19, 05:19 PM
Mingofish
Mingofish's Avatar
You got patience & skills !! Strong bruh !!
I’ve only wrapped a hood and few small pieces. Would never attempt a whole car. Skeered.
Old 12-30-19, 06:27 PM
baboya96
baboya96's Avatar
Looks great but wouldn’t it look even better if you cover the chrome trim with black to match the rest?
Old 12-30-19, 07:36 PM
diggdyone
diggdyone's Avatar
Thumbs up
Thanks Man.....You sound just like me 5 days ago....if you did a hood you got this...
BossMoss (12-31-19)
Old 12-30-19, 07:44 PM
rp2000r
rp2000r's Avatar
Very nice job, you did it the right way that’s forsure and didn’t have to worry about someone else cutting corners or damaging things on the car. 👍🏽
BossMoss (12-31-19)
Old 12-30-19, 10:04 PM
Mingofish
Mingofish's Avatar
Diggdy
saw you from ga. Atl metro or surrounding area?
Need to get some peeps together for a mini meet once holiday stuff settles.
like to see that wrap in person!
The following 2 users liked this post by Mingofish:
BossMoss (12-31-19), tuscani66 (12-31-19)
Old 12-31-19, 12:55 AM
diggdyone
diggdyone's Avatar
Diggdy
Yes Mingofish, I'm near the A....I plan to make it to the next Caffieine and Octane 1st Sunday
Old 12-31-19, 01:57 AM
diggdyone
diggdyone's Avatar
Default Diy rcf wrap write up
"Wapping a car is all about problem solving and learning as you go", Diggdy
THE NUMBERS:
Front bumper 130" length
Fender 56" length
Hood 77" x 60"
Trunk 24"
I will let the pictures and links help explain.
TOOLS and SUPPLIES: ebay, Amazon, Harbor Freight, Metro Restyle, Fellers
10 mm socket is your friend
Snack bags ...for bolts
sharpies ....label the bags...you will forget what goes to what...
Monkey tape
LED head flash lights
batteries alot of them
KNIFELESS TAPE!
Avery RED flex squeegee
MOLD N HOLD tape (for clean up)
jack
jack stands
rollong stool
ipad or laptop
YOU need this..... get 2
BFF
I KNOW....BUT I have been using them for everything.....
MOLD AND HOLD
HELP REDUCE SCRATCHES
must have for roof, quarters, trunk .....
HOOD AND FENDERS 1ST vary easy to do alone and a good way to get the nevers out......
HOOD VENT REMOVED
FENDER SIDE VENT PULLED OUT ......NOT OFF 2 screws in the wheel well and 2 clips on the vent ...just pull
'HOW TO' links I learn from.....
NOTE...I used a heat glove wet with spray wax to lay the vinyl...this keeps down on scratches, then I post heat and squeegee as needed
how to remove the hood vent
Fenders same as the hood lay with my hand using a glove squeegee later
HOW TO:
THE 3 PEICE CUT (quarter, door, and opposite side rocker)
THE BLUE PRINT
here I set the paper behind the f logo measure the rocker 1st and cut from the rear up to front green tape is my NO GO line 2nd the door is cut from above the rocker 3rd the quarters are left over... no need to cut..as seen on the video
use magnets to hold the top off the floor
extra hand...... monkey tape
127 inches.....
here is the cut out of the rocker from the driver side.....a lot of paper, which makes life easy to wrap
MY RCF WRAP PLAYLIST:
https://www.youtube.com/playlist?lis...TNiuOfncnnZ1nA
HOW TO:
HOW TO REMOVE DOOR PANEL. HANDEL and MIRRORS:
EXAMPLE ON A RC (slow videos down):
THE REAR bumper step by step with pictures. This part was a problem because the RCF has a recess in the side then it goes flat.
1st glass the center
glass the corners and pull up
3rd glass that recess
that part in the circle...hard to glass....2 moves required pull to the front squeegee , then pull up and down for glass squeegee... the top under the tail light will glass as you pull to the front
The following 3 users liked this post by diggdyone:
05RollaXRS (12-31-19), BossMoss (12-31-19), Pazorell83 (04-11-21)
Old 12-31-19, 01:04 PM
05RollaXRS
05RollaXRS's Avatar
Great post. Very informative.
BossMoss (12-31-19)
Old 12-31-19, 07:16 PM
BossMoss
BossMoss's Avatar
Dayyum! You got mad patience. It turned out freaking awesome!
05RollaXRS (01-01-20)
Quick Reply: I wrapped my rcf
