Gaskets for borla exhaust
Old 02-11-20 | 11:00 AM
jafsport's Avatar
jafsport
Default Gaskets for borla exhaust
Will the oem lexus gaskets part:90917-06070 work with any aftermarket exhaust including borla?
trying to avoid a CEL.
thanks.
Old 02-11-20 | 05:02 PM
05RollaXRS's Avatar
05RollaXRS
OEM gaskets worked on my Invidia catback so I would assume they should work on the Borla as well.
jafsport (02-11-20)
Old 02-11-20 | 10:35 PM
tuscani66's Avatar
tuscani66
OEM will work fine, as mentioned above, but mind the left / right side as they're slightly different when reusing them to ensure a seated fit. Also note that you may have to go back in and re-torque them again after a few days.
Old 02-12-20 | 05:59 AM
jafsport's Avatar
jafsport
thanks.
thanks! How do i know which gasket is for which side? Is it noted on the packaging?
Old 02-12-20 | 06:47 AM
Kramer's Avatar
Kramer
Part numbers are different. Maybe try to find an exploded parts view and have that handy when you install them.
Old 02-12-20 | 09:12 AM
jafsport's Avatar
jafsport
Thanks i just put in an order for the gaskets. i will double check to make sure the right one goes on the right side.
Kramer (02-12-20)
Old 02-16-20 | 10:39 PM
diggdyone's Avatar
diggdyone
I replaced the gaskets when in the Borla was installed and as you can see the new gasket looks misshaped, but works.
both sides old ....one new
old burned down
side by side
TiAgBlur
North Texas Lexus Club
05-21-19 05:05 AM
Mattyp
08-22-16 05:32 AM
737NG
IS F (2008-2014)
15
09-18-15 07:54 PM
UTGS400
Southwest
03-21-06 03:02 PM
Kharizma
Performance
05-07-05 09:22 PM
