Wear sensors on brake pads
Looking at some Winmax W3s on RR Racing's site and noticed that it says "wear sensors are not integrated into these pads". Can't you just use the existing sensors in the car?
Assuming the OEM brake sensors and still intact, yes you can. Also assuming the new aftermarket brake pads you are using has a same notch to clip the OEM brake sensors into.
Recently I did my own front brakes and I used aftermarket parts from online Rock Auto without any problems.
I took detailed close up pictures of everything so that I can figure out how everything fits together just in case.
