So I bought the car and it looks like it's lowered. Below is the photo of the dealer ad. Is there a way to view what kind of springs it has or do I need to just remove the whole shock assembly? I tried to view from the wheel well and I couldn't do it.
Looks like a very mild drop (if it is). Looks very close to stock height. I think if they are aftermarket then it is Swift (which is a good thing since they have good spring rates on RCF). They have under 1 inch drop. RS-R is garbage with aggressive drop, but many suffered blown shocks with RS-R due to cr*ppy spring rates. You definitely don't seem to have RS-R. I believe, you will have to take off the wheel or put the car on the lift to see what type of springs they are.
Here is mine on stock height. Your gap looks very close to mine on stock suspension. Probably might be a 0.8 inch drop on yours.
Thanks Rolla. I'll measure from the ground to the top of the wheel well when I get home today. At that measurement, where is stock usually? 27"? 27.5"?
I want to compare my drop with people on stock springs.
I can give you that tonight after work tonight. The rear is slightly higher than the front due to bigger circumference on the rear (26.6 inches rear and 26.0 front on OEM size tires). However, my car is parked on a slope so it might be a bit off. Not sure how off would it be, but I will put it up anyways.
fyi... My RCF (stock) is 27.0 inches front, 27.3 inches rear, to the top of wheel well.
That is what it looks like, but sometimes the alignment/camber etc. can skew the gap a bit. Swift is around 1 inch or maybe, slightly less. Did you check if you have any spacers?
If they turn out to be RS-R, I would get rid of them ASAP before the shocks blow.
