Brake pad decision. I want some opinions.
#61
This doesnt make sense, nor is it why you spend more money on track or track oriented pads. In spirited street driving and/or a panic stop, you arent going to get brake fade from cheaper pad selection.
Theres plenty of reasons to buy nice pads. Street driving isnt really one of them. At least not on this car, where your options start around, what, 220 bucks a pad? Thats laughable for no discernible street performance difference.
Heat tolerance aside some people are just fine with spending some more money for a pad with higher friction, better feel and/or less dust than the OE pads for purely street use, particularly on their higher end luxury performance car. Again, it's all about how you use the car and what you prioritize. I usually do 20+ track events each year and am constantly testing/using various track compounds to pair my own subjective feedback along with objective data to our customers. I've just gotten used to higher friction pads with better feel and feedback and so even on my daily street cars I'll always opt for something better because I simply can't stand the lack of response, feel, linearity of friction etc. from most normal cheap street pads when I live in an area where I use the brakes so frequently. Yes, they stop the car in the same distance for a panic stop or two but I enjoy driving and in my opinion they detract from the overall experience so I'll always just pay the relatively small premium to be happy with the brakes.
-Matt M.
#62
#63
They only way to find out is, when you try your brembo and liked it then its a score...if not, then you know that you wouldn't be buying that for next time. i suggest enjoy what you have right now...
#64
by the way how fast have you gone on Big Willow?
#65
Ill definitely do a a review and drive it under stop and go, highway, and canyon driving as well. Now am I going to go ballistic initial D driving? No. But I’ll make a fun jaunt up and down our many Malibu hills roads and get them warm.
#66
#67
thread hi jack..lol
this is the clip of my run. first time there at the track... by looking at the list on big willow, im on the list between honda civic hybrid and prius hybrid..lol..
https://fastestlaps.com/tracks/willow-springs
The following 2 users liked this post by chris07is:
cvt (06-20-20),
SpeedFreaksUSA (06-22-20)
#68
-Matt M.
lobuxracer (06-23-20)
#69
The first G is cold. The second G is at a higher temperature. GG is pretty impressive for any street pad. Few deliver this performance. Still doesn't mean I will like it, but it's not bad for starters.
#70
Not to go too far down the rabbit hole but or be overly critical but in order to attain a GG rating friction can't drop more than 22% from 250*F-600*F. I say it's more of a friction rating than a temp rating because, for example, a pad that drops 21% indicating pretty severe pad fade at less than 600*F would still earn a GG rating. To make things slightly more convoluted to my knowledge it's an honor system for manufactures to do their own testing and present their own data for a rating (similar to tires and their UTQG rating which are literally meaningless these days). I may seem overly pessimistic about manufacturer's "data" but I see huge companies like HAWK (and plenty of others) publishing laughable numbers because it sells more brake pads. HAWK's DTC-70 compound for example is rated by them to generate a peak of .86 Mu from ~1,000-1,400*F which if true would be at the extreme upper end of what a modern F1 car could handle and absolutely undrivable on any street car with boosted brakes regardless of how much aero or what tires it was using. Point blank it's just untrue. That's not to say these Brembo street pads aren't truly good pads for how you intend on using them but I do think the rating on these or any other pad should be taken with at least a small grain of salt.
At some point in the future if we can scale a bit more I'd love to have access to an in house brake dyno to cut through all of the BS and compare different compounds on the same dyno using the same parameters in order to reduce variables as much as possible. We'd be able to get truly apples to apples comparisons between different compounds.
-Matt M.
cvt (06-25-20)
#71
It's definitely a good indication that it's a more performance oriented friction material. However, to play devils advocate the high temp friction rating is measured at only 600*F/315*C which is what the pads would see in single panic stop situation from highway speeds since thats all a street pad needs to be rated for.
-Matt M.
-Matt M.
#73
And yes to everything Matt said about the ratings. No one uses them as a reliable source of information for anything other than street duty, and the windows for performance are pretty wide, so, as I said before, GG isn't bad, but it doesn't mean I will like them for sure at all. I would truly hope Brembo wouldn't be fudging their ratings given they know full well the original pads are all FF. At their price point, equal to OEM would be just fine too.
The following 2 users liked this post by lobuxracer:
SpeedFreaksUSA (06-26-20),
Yri (06-24-20)
#74
EDIT: Wait... do you mean the front vs rear pads?
#75
nope, not on turn 9, on the straightaway... turn is 9 pretty wide and scary...i already spun around on turn 4, so i would like to get home with my car in one piece...lol
https://www.youtube.com/watch?v=iQ-3RJLCfQU
