Lexus RCF track edition hotlap
Good acceleration off the corners due to the track-friendly new gear ratio.
You can tell the thing really needs to have tons of negative camber dialed in...if only the front control arms allowed for flexibility.
Do you know what tire pressure was run? I have picked up three seconds on tracks by going up 5 psi cold over the recommended in the door sills. I know...I doubted it would happen too. I did it to prove the track manager wrong. I was proved wrong! Dang! Cars with zero degrees front camber stinkin' FLY with increased air pressure (300 treadwear and below).
Thanks for posting. I need to go get some track time!
My car, which is lowered just a little, had around 1.4 on the front before I had Fuca installed, so stock height should be just a tad less. Guessing like 1.0
While cornering when the suspension squats, the camber will increases so im guessing a stock rcf during hard cornering would be at like 1.5’ish.
Currently running 2.8 static in the front. Seems to be good for most fast tracks.
i check the tire temp and the inside vs outside is only max like 5 degrees different.
Typically only 2-3 degrees.
Yri (06-21-20)
Thats sounds close and it’s static.
05RollaXRS
RC F (2015-present)
10-15-19 08:25 AM
