The f is idling weird!
Ok thanks for the information. I was on the phone with one of the F guys I know and he helped me reset the ECU but after 5 mins the lights came back and the idling issue came back. I was driving yesterday and I noticed I had to step on the brakes a little harder than usual, I don’t know if that’s got anything to do with it. I had no idea how fragile those hoses were, I didn’t move the AOS that much when I emptied the catch can. Do you know how I can get the hose? Or the part number? Thanks for all the help guys. I have been stressing, I hope my engine isn’t going to blow up or something
mjn88 (07-02-20)
Which part of the hose is cracked? The factory hose or the aftermarket added-on catch can hose? The factory one is 12261-38130, it goes from the top of the engine block (under the manifold) to the intake manifold just behind the throttle body. Do not get it undone or pulled off the engine block end, or it will be tough to get in back on, might need to remove the intake manifold. With not enough vacuum, the brake booster isn't getting enough assist so that's what you're experiencing with the brakes.
this is the hose I think is cracked, as you can see the installer tightened the clamp like crazy and I guess I might have moved the hose and i think it cracked right there. There’s some electrical tape around it right now. I called a shop and they want to charge me $800 to fix this
Looks like there's some slack in the hose, if so, you might want to try to cut the hose right on the crack and perhaps a little at the foam insulation and sheathing so the clamp fits over the new portion of the hose.
mjn88 (07-07-20)
Did you ever get this figured out?
So I took it into the shop by my house and they fixed the issue. Apparently that hose got loose under neath where I couldn’t even see. They put a clamp on it and swapped my plugs out for new ones. Everything is good now, they reset the ECU so I’m just gonna break her back in and everything should be fine. Thanks for all the feedback and advice guys
