Quest for more induction noise: My cold air intake thread
Long story short, I know the cold air intake mod even with a full conical filter element yields minimal HP gains. I am more after the noise. It is all about the noise. Based on my research, an intake tube alone is not going achieve that. Having had injen cold air intake on my Corolla XRS for many years, the conical filter element really makes the deep/broad resonating induction noise.
I want to retain the stock airbox design (with 3600 rpm flap opening) so that only leaves me with Takeda cold air intake as the only option. Wish the RR racing carbon elbow had a similar conical filter element attachment like the Takeda. AEM intake is another option, but it gets rid of all of the OEM airbox design, which I don't want to.
I would love to get a carbon intake with a conical filter element that works with the OEM airbox. It is about $500 CAD so it is worth a try for sure. If I end up getting it, I will definitely put full details here.
If anyone had Takeda on his RCF, I have a few questions:
- Dry filter vs wet filter, Which one is the better option? I want to go with the oiled one, but I have heard there is a risk to the MAF sensor?
- Is the installation as straight forward as the video by AFE shows? I might try installing it myself. Any challenges? Looks fairly straight forward from the video I have seen.
- How is your experience with the sound over the stock airbox? What are your subjective impressions about the noise?
- Any negatives about this intake? Again, I am OK if there were no noticeable power gains. Just want to see if something OEM box did better than this aftermarket intake?
Here is what I fouind:
Installation video:
AFE dyno (using a member on this board). Peak HP gains are minimal of around 5 whp. Almost none at 7100+ rpm, but seems like there is some better midrange there. Anyway, as my disclaimer above, any HP gain would be a bonus. I am looking for deeper/broader induction noise.
Installation video:
tekjunke (07-16-20)
Not an RCF, but I was the first adopter of the Takeda intake on my ISF on this forum. That was over ten years ago:
https://www.clublexus.com/forums/is-...-takeda-3.html
See Post #43
I went with the wet filter element four years ago:
https://www.clublexus.com/forums/is-f-2008-2014/485878-new-is-f-short-ram-intake-from-afe-takeda-6.html
See Post #90
1. I liked the wet filter better. As far as damage to the MAF, as long as you clean and reoill it properly you wont have an issue. Over the years I have used both K&N and AFE wet elements and never had an issue. After reoiling I always let the filter sit on a newspaper overnight and in the morning wiped off any residual oil before reinstalling. Again, never over oil and never run right after oiling.
2. Installation on the iSF was straight forward IMO. But I installed most bolt-ons, other than exhaust, myself.
3. The intake was louder than stock when the flap flipped open.
4. None that I can think of. Some folks have lost the clips that hold the two halves of the box together. That's serious because the clips are not available separately. Just be careful you don't lose them.
I liked the intake a lot because unlike others this box is pretty much sealed for underhood heat. Wish there was something like it for my LC
Lou
See Post #43
See Post #90
Lou
The following 2 users liked this post by flowrider:
05RollaXRS (07-16-20),
BossMoss (07-22-20)
Thanks. Great feedback. How long before you had to re-oil the wet conical filter? I believe the first time you just only install it since it is pre-oiled? My RCF is only an occasional car that I drive once in a while so trying to figure out how long before I will have to re-oil it? Thanks.
See Post #43
See Post #90
Lou
See Post #43
See Post #90
Lou
Just installed the exact intake few weeks ago on my 15 RCF.
The sounds is significant (or placebo effect...)
I opt for the dry version due to laziness to re-oil every now and then. From the experience I had in the past with other cars, it really makes no difference (unless you re-oil incorrectly).
The installation is very straight-forward. I'd say it took me around 30-45 min with a test drive at the end.
I have notice a slight vibration when I start the car ... but it goes away once the car warms up (maybe an installation issue). It hasn't bothered me to the point to re-check the install.
Overall, at that price, I'm happy with this intake.
Thanks for the feedback. The conical filter combined with a smoother/larger intake pipe (without resonators) will make more noise than stock CAI. How do you like the sound over the stock intake? How does it feel when the flap is closed below 3600 rpm? More or less like stock? Any torque loss noticed?
Does that red sticker seem to come off easily? I would like to look it clean and simple without any stickers on. Thanks.
I have a K&N in my car but removed the oil filter as 5 horsepower isn’t worth the risk of sucking in additional dirt & oil. So I stuck the stock filter in and kept the larger intake elbow.
LOL..it is a very simple mod and does not cost that much unlike a full exhaust system. It is not popular amongst the RCF owners because the stock airbox is so well designed already, but I am all about enhancing the driving experience. I have done cold air intake on my other car so I am looking for a broader and deeper sound. It does not help that the airbox is on the passenger side so the passenger gets to hear a lot more of the induction noise than the driver.
Takeda intake
I have a Takeda intake with AFE dry filter. The sticker comes off pretty easily as I removed mine. The maf plug is under the piping vs stock on top. I have my flap open all the time and I find it a little more aggressive sounding and quicker. I know there was a threat regarding the flap mod. The noise is pretty good as you can hear it especially with the hood open. I have a Borla so you should hear it even better with your Invidia. I paid about $300.from summit racing about 2 years ago. Hope this helps. If anything it's definitely aesthetically pleasing.
Intake
I just had a friend rev it in the car with the hood open so I could get an idea not under load conditions what it may sound like .I've tried the flap both ways for many miles and just like it better open.
Thanks. One more question, any unpleasant rattles or vibrations at any rpms you noticed?
It's been proven that power is lost with the flap open at all times:
https://www.clublexus.com/forums/is-...ntake-mod.html
For you RCF folks - The ISF guys have done what you guys are doing years before you folks thought about it. There is a wealth of knowledge in the iSF forum that may be of interest to some of you.
Lou
Lou
