Takeda Air Intake
Old 07-26-20, 07:25 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,504 Likes on 1,802 Posts
Originally Posted by RCFNN
that would be a 8 hour drive
Then, a friend out of state might have to order it for you and then ship it to you as a personal friend. I think that is the only option.
Old 07-26-20, 08:35 PM
buister
buister's Avatar
does anyone know a company that will ship a takeda intake to california because most companys are telling me no or is anyone selling one
That's odd. I got my RR Racing intake without any issues. I bought intakes for all my cars in the past from out of state and never had any problem. Did you check eBay? Those guys don't give a damn where it goes.
Old 07-26-20, 08:43 PM
05RollaXRS
05RollaXRS's Avatar
RR intake is only the elbow/tube, but Takeda is a full system including a conical/velocity stack filter so I believe the CARB requirements might be different for each.
Old 07-26-20, 08:59 PM
RCFNN
RCFNN's Avatar
yea i cant get a full intake or even just the pipe bc its not carb legal might have to make the drive bc i dont have friends out of state
Old 07-26-20, 09:33 PM
buister
buister's Avatar
I seriously doubt it. If I take my car to the smog check with the RR intake, I'll fail on the spot. I don't think there's any distinction between what kind of intake. If it's not CARB, it's all the same.
Old 07-27-20, 11:37 AM
RCFNN
RCFNN's Avatar
is there any hp gains with a intake or just the sound
Old 07-27-20, 11:48 AM
bajong
bajong's Avatar
I have the Takeda intake and although they say it might make a small power difference, I think it is primarily sound. The guys from RR racing say there is no power increase with just an intake. You need headers and/or exhaust to get any power gain.
Old 07-27-20, 12:31 PM
RCFNN
RCFNN's Avatar
does it sound pretty good or what was thinking of the takeda too but its 400
Old 07-27-20, 06:56 PM
05RollaXRS
05RollaXRS's Avatar
It is priced reasonably. From what I have heard, maybe @bajong can confirm, but the intake amplifies the stock cold air intake noise and you hear more roaring noise in the midranges. At high rpm, the intake will be louder than stock. I have had cold air intake (Injen) on my other car for 15 years so I am very familiar with the CAI characteristics. If you try to "lug" the engine, it might make some drone, but would not be an issue if you don't lug the engine (low rpm and high gear).
Some people told me, the throttle response and the midrange feels stronger (which is what the dyno says as well). Though, peak HP is not significantly different. They don't claim any different. Peak HP difference is only 5 whp and then from 7100 rpm to 7400 rpm, there is no gain at all. However, in the midrange from 4000 rpm to 6000 rpm, the torque gain claim is around 10 ft-lbs.
tuscani66 (07-29-20)
Old 07-27-20, 07:24 PM
javrabbit
javrabbit's Avatar
Do these cone filters normally breathe better than the Drop in filter alternative?
Old 07-27-20, 07:27 PM
05RollaXRS
05RollaXRS's Avatar
Yes. they have a lot higher airflow rate especially the wet ones as it seems to capture air from all angles as opposed to the flat ones that only capture air being fed straight through. However, the ECU only allows up to a certain flow rate and will adjust to what maximum can be allowed.
javrabbit (07-27-20)
Old 07-27-20, 10:32 PM
RCFNN
RCFNN's Avatar
any difference in power between the wet and dry
i just purchased the dry one
Old 07-27-20, 10:39 PM
05RollaXRS
05RollaXRS's Avatar
There is no advertised difference. Wet one has higher airflow rate and it also uses oil to capture contaminants while the dry uses only the filter to capture all contaminants, but is less porous. I don't think it would make a noticeable difference power wise.
Old 07-28-20, 08:06 AM
bajong
bajong's Avatar
Yes, I can confirm this is true...to my experience. Great review by the way!
javrabbit (07-28-20)
Old 07-28-20, 11:24 AM
javrabbit
javrabbit's Avatar
Im sold, definitely going to pick one of these up before i get the dyno tune so i can make use of the higher air flow and better sound.
OP, i can get one and ship it to you from Arizona if you're interested. PM me.
Quick Reply: Takeda Air Intake
