Customizations
Customizations
Can anyone tell me please, if Techstream V15 has the ability to make the modifications mentioned on Manual OM24636U page 641?
I couldn't find it. And Carista also does not have this listed.
Thank you.
Thank you.
Not sure if if the RCF is the same as the RC 350 but I changed mine with this procedure;
■ Changing by using the Remote Touch Press the “MENU” button on the Remote Touch. Select “Setup” on the menu screen and select “Vehicle”. Select “Vehicle Customization”, “LEXUS Park Assist” or “Drive Mode Customization”. Various setting can be changed. Refer to the list of settings that can be changed for details. For details on the Remote Touch, refer to the “NAVIGATION AND MULTIMEDIA SYSTEM OWNER’S MANUAL”. ■ Changing by using the meter control switches P. 111, 129 C
I do have the Carista module however its in my Audi because that was more sensitive, I used a generic ELM327 Bluetooth model on the Lexus.
You can change the number of flashes yourself. There is a DIY out there concerning auto flashes that I used to change from 3 to 5. Kind of complicated, but on the 3rd try it worked for me!
Thk u in advance.
I just got home - I'll run out to the car to try with Carista and if its on there (because I did it, and lowered the volume among other settings I did) I'll do a screen capture.
br116 (08-03-20)
No worries, thank you.
Below from Carista developer, today.
...........Thanks for getting back to me. I'll be able to confirm whether we can do those changes or not when we get debug data from the vehicle. It gives us technical information about the electronic modules in your car. That way, we can check what coding the car supports.........To send debug data, please follow the instructions from the last item in the link below:
https://help.caristaapp.com/hc/articles/360009767940
I haven't tried it myself, but it's the first helpful hint found here: https://www.clublexus.com/forums/rc-...ful-hints.html. No tools/apps needed.
Now I have to save Techstream to other stuff and justify the $$ spent.
One thing I notice on my 2017 RCF (not sure if it changed recently, but could explain why the dealer couldn't get it right).
In this section, mine were backwards:
- 1 flash = set for 3 blinks
- 2 flashes = set for 5 blinks
- 3 flashes =
- 4 flashes =
Mingofish (08-05-20)
