RC F Front Camber Adjustment
Are there camber bolts or some other means to adjust the front camber? In had an alignment done after I installed lowering springs, shop said there was no way to adjust the front so they are a little out of spec.
The rears are a maximum of -2.3 with a minimum of -0.8. Caster angles are also to be 7.63 with a tolerance of +/- 0.75
To adjust camber/caster at the same time, you'd have to adjust the positioning of the front subframe. Most cases of off-wack camber and caster settings are from a not so well positioned front subframe. Check your caster angles and compare them side to side. Also, your front camber and rear camber are going to be a little out of spec anyhow considering you're lowering the car. Lower = more camber on most suspension geometries. I believe the OEM specs were -1.2 front max, to 0.3 minimum, with the default setting being -0.47. Pretty low camber numbers for a sports car...
The only way to adjust the camber would be with an aftermarket upper arm and the only one I know of is made by FIGS.
Personally I’d just leave it where it is unless your tracking the car and in which case you may want more camber.
