Did you know that there is a stupid piece of plastic hanging on the rear wheel well that is there so the stock tires do not extend beyond the body which would be illegal?
Yeah, I'm aware of that, but does the tire really extend outside the body?
The gap will become larger, 295/30/19 tires are the same diameter as 255/35/19 (oem front) tires. 275/30/19 tires are .5 inches smaller in diameter than 255/35/19 tires, 295/30/19's are smaller than 275/35/19 (oem rear) by about .6 inches.
I would focus on getting more aggressive compound tires rather than wider since already 275 mm in the rear is wide enough for around 500 HP. Getting sticker compound with aggressive shoulder profile will make it feel way better.
