OEM Brembos vs RR Racing Gyro BBK comparison test
Really insightful. Though, the comparison is with OEM having 100K miles vs brand new RR Racing ones so the stopping test is not exactly apples to oranges, but the huge loss in rotational mass alone makes it a great modification. Once my OEMs are done, I will look into getting these.
1wacko (11-08-21)
LEXUS RCF Brake Rotor Performance Test Comparison 1 PC BREMBO VS 2 PC RR-RACING/GIRODISC - YouTube
I appreciate the real world test though. The rotational mass savings alone is a plus. Not cheap. I can get OEM Brembos for the fronts for around $250. I think these are $1,200 for the front. But that distance is quite significant.
I wonder what brake pads he is using?
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
Pretty sure Barry was using his old pads...smh..lol. At least in the first video he posted on facebook he just reused his pads. Which... if I'm honest is kinda silly. You have nice new two piece rotors, CHANGE the pads. Also one thing I noticed is that on the first braking test he did not engage ABS, but in the second run with the giro discs you can clearly hear ABS kicking in. Which is why I think he had longer stopping distances on the first test run. He wasn't hard enough on the brakes.
I have Giro discs on my STi and I love them. I think I'll be picking these up shortly. It's a shame because I only have 200 miles on my car so the rotors are new. But loosing rotational weight is key especially when you do it on all 4 corners.
Giro discs are almost too nice looking to use. I was sad when I put them on my car because they were just so beautful. The quality is there 100%. Porsche guys swear by them as well.
-Nigel
-Nigel
You mean apples to apples? Apples and oranges make a good fruit salad. 🤣
-Nigel
-Nigel
While decreasing rotational mass is good, I don't see how it would be worth over 2 grand front and rear. As Nigel said, you can hear the ABS actuating more aggressively on the Girodisc runs. Realistically speaking the main noticeable factor (if there really was any to begin with) that lowering the rotational mass has on braking is that the ABS could pulsate faster, up until the software limitations, of course. They look good and they might help make the car perform a little better, but remember, this is a 2 ton car we're talking about here.
LOL...that is true. Good catch. Yeah, the total loss of rotational mass is 34 lbs or something on all four corners. Considering it is rotational, which means it has an exponential effect on inertia as the speed goes higher, the net effect is a lot more than what the 34 lbs might suggest. I still have I think around a couple more spring/summer left on my OEM and I will definitely get these ones as the performance gains are pretty significant.
I think he did a pad replacement video a while back. However, he did not replace both of them at the same time.
How to change Lexus RCF Brake Pads and Brake Fluid Flush - YouTube
Those pads would have gone in the trash if they were me...rofl ;-p
-Nigel
I think Lost has the same two piece if I’m not mistaken. I watched the video again and that braking distance difference is huge. I thought tires would have a larger effect on braking distance but he did do repeated stops which favors better pads and rotors.
oh lawd help me! keep the mod demons away from my pockets! LOL
I have the R&R 2 piece rotors. They were so pretty when I installed them.
While these YouTube tests are far from perfect, the experience is about the same, meaning that the it takes less braking force to stop. To say another way, if the same braking force was applied in both tests in that video, then it makes sense that ABS was kicking in because there was less rotating mass to contend with. I'm actually glad he used the same pads for his test so that the impressions show the benefits of just the rotors and not the combined benefits of rotors and fresh pads.
I personally wish I had just done this mod early instead of waiting until I needed new pads to make the swap.
7schulz
19
05-26-10 05:25 PM
