Rcf tune
Rcf tune
has anyone tuned there rcfs after getting an exhaust and headers if so what tune module did you buy and did you take your car to a tuner for a custom tune?
I have intake and full exhaust (stock headers). I have the RR racing ECU tune. Very happy with it. No complaints. I did the remote tune so it is all using your laptop of reading/writing files via a dongle that is sent via mail by RR Racing. There are very noticeable gains especially in the midrange, paddle shift response and also power as well. My Dragy runs seem to be supporting that.
No off-the shelf tune will give the same or even favorable improvements across the board. If you cannot get a custom tune you are better off not doing it at all is my thought about it. If you proceed with an off-the shelf tune do yourself a huge favor and get a before and after dyno. If the tune doesn't work you can revert back to original factory tune or send the datalog back to the tuner to make adjustments if possible. Most optimal scenario is still a custom tune specific to your car.
Already seen a couple of verified off-the shelf tunes give negative performance to understand it is a potential issue and it's not isolated to one tuner.
How do you arrive at this conclusion without baseline numbers?
Because of the numbers it is putting down at 5300 feet DA, They are only possible with significantly more power across the board than stock.For example, best trap speed I got at that DA is 113 mph and it's translating to almost a, 119- 120 mph trap speed at sea level. I am waiting for the DA to go down hopefully in September or October as it gets colder and dense at night in those months and see how it affects the numbers
Like a baseline summer run to compare to when the weather changes?
Yes just a couple of times.. My initial/first 60 - 130 mph run was 12.9 seconds (slammed into rev limiter in 2nd to 3rd and 4th to 5th, I believe) at a DA of 5300+ ft, but it is just the first few tries. It was just the very first run. The issue is the 4th to 5th shift. It happens just before 130 mph at around 127 mph. I am trying to figure out if I could stretch 4th gear to 130 mph. I have done only a few runs so there is more figuring out to do on shift points. It will go down to around 10 - 12 C at night time in September and October with higher more moisture content. I am hoping to see the DA go down significantly in Sep - Oct, hopefully.
Your circumference must be larger. 20 inch wheels? I am on the OEM 19 with 20 spokes. Maybe, next time I will try to hit the rev limiter in 4th gear and see if can get up to 130 mph on the Dragy before shifting up to 5th. Forgot to mention, I also had 50% fuel. I can get it down to low 12s possibly, if I can get all of the things figured out. The colder/denser air in Sept - Oct also should help bring the DA down significantly.
I have straight pipes and about to get my PPE UEL headers installed in about 2-3 weeks. I'll probably be going with "Tuned by Loi", you can also check out "Delicious Tuning".
Delicious tune is garbage. You end up losing power. I would not recommend that. Tuned by Loi seems to be quite good. I heard Tuned by Loi also increases the rev limit to 7600 rpm or something.
Gives you higher revs and if the horsepower is not dropping, it will make give more power through the rev range. Since RCF engine breathes really well at high rpms and pulling hard before the rev limit, probaby is making really good power/torque past 7300 - 7400 rpm stock limit. That is with Tuned by Loi. My RR Racing tune still has the stock rev limit so it is more on the safer side.
On another note, all this talk sure is giving me the bug for power upgrades... All the headers / exhaust talk is drool worthy. Better intake and a new tune as well. Cant do all at once (unless my bonus for my current project is HUGE)(i doubt it). Might have to start with the intake...
I went looking for any stock dyno charts to see if it would show when the HP would start dropping off. I did not find as many dyno charts as I thought I would. what little I could find was showing the HP dropping off a little bit starting at the 7100 -7200 area. That could be from just being stock with stock setting. I'm not sure. I personally am not a fan of raising redline with stock internals.
Louczar1 (09-02-22)
Louczar1 (09-02-22)
