Road Course and Auto-X Discussion about road course, time trial and autocross racing.
2UR-GSE Engine
Old 08-10-17 | 12:41 PM
TGV8's Avatar
TGV8
Default 2UR-GSE Engine
Thought some of you would enjoy this 2UR-GSE engine build:
Stock block and head casting
5.0 Liter
600+ HP
500+ ft./lb.
381 lb. dressed weight
Designed, built and tuned in 100 days
Enjoy
Attached Thumbnails 2UR-GSE Engine-img_1821.jpg   2UR-GSE Engine-img_1762.jpg   2UR-GSE Engine-img_2073.jpg   2UR-GSE Engine-img_2069.jpg   2UR-GSE Engine-img_3115.jpg
The following 4 users liked this post by TGV8:
2013FSport (10-02-17), EDUSAN (12-24-22), ilGalante (09-13-18), JauntyBishop (04-08-24)
Old 08-16-17 | 10:21 AM
Leander311's Avatar
Leander311
Stunning... What's the application? Redline?
Interesting 90deg bed on the collector of that header...
Old 08-17-17 | 10:21 AM
ba2sy's Avatar
ba2sy
Subscribed...
Old 08-18-17 | 12:09 PM
TGV8's Avatar
TGV8
Thank you for the compliment. This was a fun project.
The application was a development project for endurance road racing.
Redline in this iteration is 7500 RPM, and is a product of its air inlet restrictors (38mm x 2).
Without air restrictors, and some modifications to the camshafts / chain guides / tensioners / DI Pumps, it will easily rev to 9200 RPM
The 90deg bend in the secondary exhaust relates to it's routing in the chassis.
EDUSAN (12-24-22)
Old 08-18-17 | 12:56 PM
Leander311's Avatar
Leander311
Whoa! So you've choked flow at 600hp at around 7,500rpm? In theory that's >700hp at 9200 given similar VE and some added windage losses. What a beauty.
EDUSAN (12-24-22)
Old 08-18-17 | 02:00 PM
TGV8's Avatar
TGV8
Restrictors for this application are unfortunately defined by FIA regulation, so there is not much freedom in design. If the only constraint were 3mm of the minor diameter, the same power could be achieved with a much smaller restrictor with a proper 270 deg entry and appropriate convergent / divergent angles - such as this 29mm pictured below.
Old 08-22-17 | 10:27 AM
TGV8's Avatar
TGV8
Originally Posted by kitabel
Are you allowed to mask the required shape?
Unfortunately not.
Old 09-16-17 | 09:17 PM
liquidtek's Avatar
liquidtek
Just found this thread. Awesome build!
Old 10-02-17 | 07:03 AM
TGV8's Avatar
TGV8
Old 10-02-17 | 07:29 AM
TGV8's Avatar
TGV8
jct23 (10-02-23)
Old 10-02-17 | 07:52 AM
2013FSport's Avatar
2013FSport
That's beautiful...
Given its BHP/liter/mass, how is stacking up compared to other entries in its class?
Where is it headed i.e. drivetrain and chassis wise?
Old 10-02-17 | 10:54 AM
TGV8's Avatar
TGV8
Originally Posted by 2013FSport
That's beautiful...
Thank you.
Unfortunately, these engines will not be raced competitively. It was done purely as a development project. They will likely end up in road cars, special projects etc.
The following 2 users liked this post by TGV8:
Old 11-14-17 | 08:04 AM
Leander311's Avatar
Leander311
Wink
Thank you.
I have a road car (even tracked at CoTA occasionally!), if you need a test bed...
Old 06-02-18 | 01:49 AM
tunami's Avatar
tunami
crazy build!
Old 08-20-18 | 05:30 PM
dicer's Avatar
dicer
Okay, so was a build from scratch project? Just a guy in his back yard shop or what?
