Transmission solenoids
I have a 1999 lexus RX300 with transmission problems. Check engine code states shift solenoid A electrical. I switched out all shift solenoids and still have same code. Weird thing is, at times transmission will work fine but when driving and comes to a stop for a bit, the transmission will go into a weird mode and start in 2nd gear? After that the transmission will not go pass 3rd gear. My rpm will be at 4000 and climb high as speed climbs higher. At times the check engine light will disappear and car runs great for a bit than right back to weird mode. Can't figure out what the root cause is after changing shift selonids. Need help!
I have a car with a similar problem the transmission is simply worn out. It's possible replacing the entire valve body will fix things or it could have further problems. How many miles? Often this transmission fails at 160-200K miles.
So what are the new error codes after the installation of the solenoids. Same as before or something new? Keep in mind you can have a mechanical problem with an aging transmission. There are thin hydraulic channels which are operated by steering the fluid by the solenoids. If a suspended particle gets in there that starts the modulation of fluid independent of the solenoid.
I have limited knowledge of outrans and beyond drain and fill, I would take it to a mechanic.
Salim
Salim
kizmazz (11-19-23)
The error code "solenoid A electrical" is simply like all other codes ... malfunction detected in operation. The actual solenoid could be bad or the wiring or even something in the sense for failure. A proper diagnosis is required although at times throwing parts ... like blindly replacing a solenoid ... can work .. that is if the solenoid was truly bad.
Salim
Salim
The same code came back after I switched the selonoids. That led me to think it's not the selonoids that are bad. I'm thinking it's a bad sensor?
Today I drove the car and it ran great for most of the day. When I started it this morning the check engine light was on, but the transmission seemed to be fine and shifted through gears with no issues. I stopped by a buddy house turned the car off for 45 min. When I started the car to go home the check engine light went away and the car ran perfect! I drove it around town for a few hours to see what would happen. No lights or weird gear shifts throughout the evening, until I went through Mc Donald's drive through. I had to park and wait for my food. When I throw it in reverse to fix my parking, the check engine light came back on and car went into limp mode. Car starts in 2 gear, shifts to 3 and stops.
Would this be transmission problems? Or sensor going on and off?
The car is at 199k miles. When I ordered new selonoids it came on/with a valve body. Didnt think to switch out the value bodies though....
Almuqarshi
01-26-19 05:45 AM
