2000 RX300 AWD Denso Alternator Replacement
#31
It's in this picture. The adjustment lock bolt goes horizontally through the same metal block that the adjustment bolt goes through https://www.clublexus.com/forums/rx-...l#post10923774 (scroll down to 2nd picture)
There are some tops for removing it in the thread. I think generally I use a ratcheting box end wrench and/or a 1/4" drive socket with a short extension past the belt, 1/4" to 3/8" adapter, 3/8" drive ratchet with long handle.
#32
Now, my understanding is that the tension lock bolt (#2 in my photos) is a long bolt that goes through the sliding block, then the (sliding) guide plate and then the alternator's mounting ear's thread hole. In this case, the long #2 bolt doesn't budge on my hand force points the bolt is likely rusted badly in the thread hole on the alternator mounting ear. I need to get penetrating oil onto this thread hole.
I am getting closer.
#33
flat6toV8
07-04-10 03:11 PM
