Programming Homelink Garage Opener on 2 cars
Any one succeed in programming the homelink garage opener on 2 lex's? I can't seem to get both to work. Any info would be appreciated...thanks!
Forum Administrator
I've got both a GS400 and LS400 - works fine with both.
With Craftman's opener, RX & GS had no problem in programing with a time gap of 1 year.
Salim
Salim
The craftsman (belt drive ) opener has what is referred as "rolling code".
My understanding is that each sending remote is registered by the opener. This registeration happens when the opener (not the sendig remote) is set in the learn mode.
Salim
Salim
actually...i thought it worked cuz i got my lex to work....BUT then realized i didnt check to see if the other first lex worked...it doesnt now!
tried doing them a couple times at the same time...no luck.
its either one or the other.
hmm any other suggestions???
I am stumped. I was reporting my observation and do not have the exact knowledge. What brand opener do you have? Ask the manufacturer on how to add additional remotes. You may get the run-around ... ask Lexus or the car manufacturer. Try to establish the steps needed to add supplimentary remotes form the SAME company (same as the one which manufactured the opener).
Salim
Salim
