Opinion on Rims
Opinion on Rims
I just wanted to get some opinions on these rims before i go out to get them. Im thinking 18's or 19's. Its graphite gey in the middle with a chrome lip. Heres my attempt on fotochoppin them on my rx.
Actually I think they look pretty good... Pic appear to be 19"
The idea of darkened wheels that are 19" eliminates the BLING factor.
Do you have any other pics like an angle shot to see the profile...?
Who makes them?
Who makes them?
I could only find a couple pictures but most of them are at side angles.
Im not sure if its 19's it was quick chop. The rims are Falken Torque5's. I made the rims on my rx a little darker than it is suppose to be. I havent seen the actual rim yet but hopefully itll look like whats on my rx.
Heres a pic:
Heres a pic:
You can get there at ebay. I found a set of 18x8's for $599.
Ya if i do get 19's the ride quality might decrease. But would it be worth it for the gain in looks? Any opionions from members who have experienced the rx with 19's?
i think those looks good. would it fit fine with the Lex?
also is there a 20"?
my 18's are good, but i want bigger, i want me some 20's but wouldn't mind going 19...
i likey them rims
i likey them rims
They fit the RX300 perfectly, BUT you must use a 235/55/18 tire. Either the Goodyear Eagle RSA or Michelin MXV4+ (which are stock on RX330's with 18s) will work fine. No spacer needed either. If you go to the larger 255/55/18 then you will need a good quality spacer, ie. H&R 15mm hub centric spacers. This wheel comes in either a 38mm or 45mm offset so be sure that you get the 38mm ones. Here's a link to the manufacturer's website.
http://www.rslwheels.com/wheels/?sfID1=12&sfID2=51
J
J
you refering to the 18's or the 19's, cuz i thinking about mabbie changing out my 18's for those 19's.
i think currently i have a H&R spacer on the rear.
lol don't mind me i'm stoopid with tires/rims haha
I would imagine that the 19's would fit fine, but make sure you can get a tire that will allow them to fit. It's all about the combination of both the tire and wheel that makes a good fitment for the RX300.
JP
JP
