Pull off the inner door panels and locking mechanisme RX300 (2001)
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Perhaps someone can help me with the following.
I had to remove the outside doorhandler for doing some paintwork after a dammage.
However unless I removed al the screws etc from the inner door panel (driver seat) included the screw by the inner doorhandler I was not able to remove this doorpanel. It is stocked somewhere by the inner doorhandler. So I managed to remove the outside doorhandler without removing the inner doorpanel totaly. But unfortunedly the lock was falling apart and some pieces disappeared into the doorinner.
So now I must remove the inner doorpanel.
Now I have to put the lock together again and I don't have a picture of it.
Does someone know why I am not able to remove this inner panel. Have I forgotten to remove some screw?
Do someone have a picture of the inner doorlock machanisme?
I would be very thankfull if you could help me!!!!!!!!!
Met vriendelijke groet,
Perry Salden
Netherlands
Perry Salden
Netherlands
i had the same problem with my old RX300. take it to the dealer and they should pop it off for no charge as long as you have all the screws and plastic rivets out. the mechanic did it in the parking lot for me, it took him a second.
veel geluk!
veel geluk!
