Key Programming
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hi,
I have a Lexus RX300 year 2000 model, and i want to program a key that i have purchased. I have searched the web for a programming method, but i havent found any luck. if you know how to reprogram a key, please email me or leave a reply to this thread.
thanks
thanks
hi,
i went the link you gave me, and it worked, halfway. i tried the instructions given by ederny with the locking and unlocking method. and it did what it said it would. i am trying to add an uncut key, and make only the remote part of it work. not the turning on the ignition itself. when i follow his directions, it does the "6) If within 3 seconds, door locks cycle one time, new
transmitter code has been successfully accepted" but the key remote still does not work. is it because the key is not cut for the car?
please respond or try to help me out...i need to get this new key programmed. thanks
i finally got the key to work. even though the key isnt cut for the car, i got the remote to work. and i used the info from the reply that BurnishedGoldRX left on this thread, and for specifics, i used the info from ederny in case anyone else needs help doing it....it took me a few days to get it working, but you just have to get the steps correct, and its very easy. thanks for the help guys
now ic an get that remote start for my car
thanks
thanks
drich2905
07-26-13 01:51 PM
