What tint for the front windows?
I had a clear bra put on today and the installer showed me some tint. it was Llumar 30 and 15%. The 15% looks almost identical to the factory rear window tint. From the inside its a bit different. The 30% is better for the fronts but won't match well. I want to get it to protect the black leather interior.
Has anyone had theirs done AND knows what was installed and the numbers for the tint along with the brand.
I read the previous tint posts and nothing specific was posted.
Thanks
Thanks
RX 300 & 350Z Guru
I remember those that did have the front windows tinted on their RX300's used Llumar brand tint as it matched the factrory tint very closely. Your right, from inside the difference may be noticeable but it is a very close match on the outside.
There are already quite a few threads about this in the RX forum. A quick search using the term "llumar" and I found these:
Fourth post gives you the film roll #
A picture of the llumar
Another angle of the same RX
It's the closest you'll find.
RX 300 & 350Z Guru
Originally posted by Stone
LXRex-
i neglected to state that I have an RX 330. Still looking for suggestions.
Thanks for the info.
LXRex-
![Doh!](https://www.clublexus.com/forums/images/smilies/doh.gif)
Well, you are in a better situation then since all you have to do is match the factory black tint. I know going close to 30% (32-35% is legal in most states) will not match the factory. Going 20% is farily dark but probably just a shade lighter than factory. I would agree that 15%, while dark, would match the rears closer than anything.
From the inside of the vehicle you will notice a difference from the factory tint, which is not a film vs the aftermarket tint, no matter what you choose. I have heard good things about the brand Sun-Guard as well as Llumar.
In my opinion, if you can deal with the darkness of the 15%, go for the close match. If not, 20% is a good compromise. Also, see if there is a tint shop near you that has the device used over windows to determine the light transmission percentage - then you would know eactly what percent the rears are.
Thanks for the info. My wife decided to go with the 15% Llumar metallic . This will make the fronts almost as dark as the rear. Should look very uniform just not quite legal. I'll follow up when its done.
always love showing off mine, but i just know its a 3M tint, nothing else.
![](https://www.clublexus.com/gallery/data/539/4879b9.jpg)
RX 300 & 350Z Guru
Does anyone know if it is legal to have mirror tint in Florida? I'm thinking about getting some mirror tint for my front windows but I want to make sure it's legal first. Any help would be appreciated. Thanks
RX 300 & 350Z Guru
vinster29, check out this website for details on Florida's tinting laws. I don't know how valid this web site's information is but it had the right information for Georgia's tinting laws - that is before our tinting laws were thrown out a couple weeks ago.
You can also check with the Florida DMV to see if they have any details on the subject.
I live in Monroe County. And work in Miami-Dade. Never had any problems with the extra tint I put on my RX300.
I put reflective in the front. And black on the back 5 windows. The installer talked me out of going with the extra dark limo tint. Glad he did. If my tinting was any darker. It would be hard to see through at night.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Thanks
Thanks
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Originally Posted by CK6Speed
Personally, I would also lightly tint the rear windows on teh RX330 as well. That is what I'll be doing along with the fronts. The factory tinted windows I believe do not block UV whereas many tints do.
Just about all factory tint glass block UV rays effectively. You can use UV-rated clear tint film if you want to be sure. I had it done on my front windows so I no longer have trucker's arm.
(or simply spray paint it over for total UV blockage.)
