Differential Fluid and Transfer Case Fluid
Old 06-30-04, 10:29 PM
autodriver
autodriver's Avatar
Default Differential Fluid and Transfer Case Fluid
I called 2 Lexus dealers about 2001 Lexus RX300 AT AWD. One told me that Transfer Case uses Type T-IV transmission fluid. One told me that Transfer Case uses GL-5 gear oil.
I called 3 Toyota dealers about 2001 Toyota Highlander AT AWD. Two of them told me that Transfer Case uses GL-5 gear oil. One of them told me that Transfer Case uses Type T-IV fluid.
I took my 2001 RX300 AT AWD to a Toyota dealer (which told me that Transfer Case should use GL-5 gear oil). When I picked up my vehicle, the service slip states
"Drained and filled both front and rear diff. fluids. 4 pints.
Transaxle and trans. has the same fluid"
Then I was charged 4 unit of gear oil, $1.50 each unit.
(If I am not wrong, 1 quart = 2 pints)
Note: My 2001 Lexus RX300 Owner's Manuals says that both Transfer Case and Differential use 1 quart of GL-5 gear oil.
I am so confused.
ajay60610
02-15-17 03:38 PM
wes77
RX - 3rd Gen (2010-2015)
09-30-11 06:57 AM
ownpace
08-25-11 10:06 PM
maintrain
Maintenance
03-21-07 01:23 AM
autodriver
Maintenance
05-24-04 11:00 AM
Quick Reply: Differential Fluid and Transfer Case Fluid
