Tightening belts (power steering, accessory drive belt)
Old 07-05-04, 10:13 PM
MrApex
MrApex's Avatar
Lightbulb Tightening belts (power steering, accessory drive belt)
Well I got a "copy" of a Lexus manual off of eBay... finally know
how to tighten these things on my own.
The accessory belt is easy. Loosen 1 nut + 1 bolt. The adjustment bolt
(tighten to tighten up belt) can be difficult to get to -- those of you
who have changed the oil filter; it's something very similar.
Gotta get a ratchet down there to tighten this bolt. Kind of annoying!
But not too difficult.
Attached Thumbnails Tightening belts (power steering, accessory drive belt)-adjust1.jpg
Old 07-05-04, 10:15 PM
MrApex
MrApex's Avatar
Default Another pic
Here's a shot of the adjustment "lock" bolt -- you just have to loosen it.
Do not remove it! It's tight fit, so you should have a good range of
ratchets/sockets to squeeze in there.
Thankfully I collected a nice amount of tools over the years
from working on tight engine bays of MR2s... so I had them
in my set already!
Attached Thumbnails Tightening belts (power steering, accessory drive belt)-adjust2.jpg
Old 07-05-04, 10:18 PM
MrApex
MrApex's Avatar
Default Power steering belt
Okay here's a shot of how to tighten this one up... this one calls for a SST
to fish through the pulley hole -- I could never get a socket to line up.
It's slightly off! talk about annoying!
So I used a SnapOn thing/angle long handled wrench -- very tight fit, but I got
it in behind the pully and loosened the bolt. Do not remove it!!
The lower bolt, I simply loosened as well. Then I jammed a jack handle
(very tough iron/steel rod) and pushed the that bolt's washer down
to put more tension on the power steering belt. It helps to have
a helper (SO/spouse/etc) tighten the bolt, as you force the bolt down.
Attached Thumbnails Tightening belts (power steering, accessory drive belt)-adjust3.jpg
Old 07-06-04, 12:22 PM
LexNatural
LexNatural's Avatar
From the looks of your pictures you have a serpentine belt in yor pictures.
The serpentine belts have a spring loaded tensioner pulley to take up the slack if I'm not mistaken.
You should not have to make manual adjustments.
Old 07-06-04, 12:53 PM
MrApex
MrApex's Avatar
Default Not serpentine
Just a really thick belt that goes around AC and alternator. It definitely needed
to be tightened manually...
nicks88
08-03-21 01:48 PM
HandsomeB
07-13-17 09:52 AM
bdruff
05-29-15 02:37 AM
gtstcactus
04-12-15 06:50 PM
jtwags
04-08-14 08:19 AM
Quick Reply: Tightening belts (power steering, accessory drive belt)
