60K Oil change on a 2000, AWD RX300
60K Maintenance
Are you going in for the 60K scheduled maintenance or just oil change? The oil change is just a regular oil change, so it should be about $30, or whatever a dealership charges now (I change my own oil). If you're talking 60K maintenance... BOOM !!! It's $1500 at dealership.
I had mine done about half a year ago and it goes with a lot of things, but it's still $1500 of BOOM !!!!
If I remember correctly it was:
Oil Change (include filter of course)
Transmission fluid
Differential fluid
Brake fluid
Check brakes
Timing belt
Accessory belts
Spark plugs (which is a b-itch on the RX to change)
There may be one or two more things of minor importance, and most were just check this and check that, which is just visual and who knows what they do.
There is no external fuel filter on the RX, just an internal one built into the pump inside the fuel tank. Supposedly never needs changing.
Transmission fluid
Differential fluid
Brake fluid
Check brakes
Timing belt
Accessory belts
Re: 60K Maintenance
Transmission fluid
Differential fluid
Brake fluid
Check brakes
Timing belt
Accessory belts
Transmission fluid
Differential fluid
Brake fluid
Check brakes
Timing belt
Accessory belts
JPI
60K service is usually around $300 to $400 at the dealer. You should know what services you want performed before going in and don't let them add a bunch of unnecessary stuff not required by Lexus. Remember, your service advisor is a salesman selling services and if he can get you to buy $1500 in services when you really only need $300, he will. I paid just a little over $100 for my 30K and 60K service at an independent shop, performing everything listed in the owners manual and using Quaker State synthetic blend oil.
Remember all dealers have different service schedules based on location/climate. A 60k in Florida could be different than a 60k in Minnesota. Just have the advisor clearly tell you what you're in for.
A 60k in Florida is the same as a 60k in Minnesota. Check your Lexus manual. If you don't believe that call the 800 #. Some service advisors like to add unnecessary items due to climate, pollen, wind or whatever else they can get you to believe. But again your advisor is a salesman, there to sell services.
What Lexus 'suggests' and what retailers actualy do can be two different things. Just because Lexus says Iridium plugs warrant replacement at 90k miles, doesnt mean dealers wont change them as part of a 60k service. Each Retailer will have its own "Maintainance Schedule", with pricing and labor calculated to make parts + labor = your price. Some stores could do belts + plugs + pcv at 60k, while other stores would work it like a 2nd 30k service. It really is in the hands of the individual dealership more than you may like to believe.
That being said, What Lexus suggests, the Dealer suggests, and what you personaly trust as being right will rarely match up completely. An honest technician would decline replacing a belt or an air filter at the time of a major service if it was new. Many however would just put new parts on and toss barly-used parts, because he isnt going to get paid for it if he doesnt do the service. Flat rate is the devil.
Make sure you get a complete breakdown of what the 60k entails, and a quote up front.
Timing Belt Change
The owners manual on our 1999 RX300 does not say the timing belt should be changed at 90,000 miles. It says to check the timing belt, nothing about change it.
My 99 RX has over 86,000 miles on it now and I WILL have the timing belt changed even though it only says to CHECK it, along with replacing the iridium spark plugs and other listed maintenance services.
GCrim21
GCrim21
If the tech sucks, and can't do a timing belt job in the time the dealership charges "Inspected timing belt, appears fine at this time, check next service" If the tech is good and can make an hour or so, you'll see "Inspected timing belt, reccomend replacing timing belt and water pump, $595 parts and labor" (or whatever)
flat rate sucks, imo.
Reason few retailers will 'package' a T-belt / waterpump job in their advertised 90k service is just that. Advertising. People who shop around (and most people do) are going to go to a dealer who advertises a $500 90k service (which is just a duplication of the 30k, say) versus one who advertises a 90k service at $1,000 even tho it 'includes' a T-belt / waterpump job.
