15K no transmission fluid change--void warranty?
Originally posted by flipside909
[ A simple drain and refill will not get rid of the old exhausted fluid that's in the torque converter.
Lexus Connoisseur
Originally posted by bob2200
I think the theory is that changing 2 quarts at a time, more frequently, will cause the new fluid to mix with the old fluid (e.g., about 1/2 new fluid on first drain/refill, about 3/4 new fluid on 2nd drain/refill, about 7/8 new fluid at 3rd drain/refill, etc.)
Lexus Connoisseur
Originally posted by mikey00
Your RX has lifetime fluid in it. Just check the owners manual or read the label on the dipstick. This is from Lexus/Toyota engineers who are more knowledgable on the subject than any of us here.
If you want good reference, check this:
http://yotarepair.com/ScheduledMaintenance.html
Tranny fluid works like hydraulic fluid. It'll last the life of the vehicle unless it got overheated a lot - such as towing a trailer or stop-n-go in hot climate.
I personally would do it every 60K, but again this is not necessary to maintain your warranty. (Read the manual and the tranny dipstick.) Also my factory tow package include a tranny cooler.
Do not flush the tranny, ever. Doing so will push debris where it shouldn't and damage your tranny. (Don't believe the AAMCO commercial.) If you want to get most of the old fluid out, just drain-n-refill twice. Measure the drained fluid so you don't have to guess how much to put back in.
Lexus Connoisseur
If you use your RX as a taxi cab, tow, or some other harsh treatment other than just stop and go traffic in CA, you should change the fluid. The service advisor "salesman of services" likes to convince everyone that their driving habits require changing it. Remember, if you have the tow package and don't really tow often, you have a trans cooler and are ahead of the game. I would never flush my tranny. This only puts more of your money in the pocket of the service provider with no advantage to you.
A simple drain and refill even doing it 2 times will not get the old ATF out.
it might void my warranty
This is another example of how each Dealer has its own "Maintainance Schedule" and they just package as much stuff together as they can to make a good buck.
While the Lexus maintschedule may say "Inspect and correct or replace as necessary every 30k miles or 24 months" Any successful dealer will turn that in to "Replace every 15k miles or 12 months".
It doesnt matter what Lexus corp suggests or publishes, its up to the individual Dealership. Its the dealers job to be profitiable, and capitialize on the affluent clientel. Also keep in mind that if a Dealer is servicing your car since new, they are more or less 'liable' for the car (at least your CSI Score, heh), IE a customer would say, "Why did my tranny blow, you should have been changing the fluid over the last 3 years". Suffice to say, no dealer is going to leave $15.00 in parts and $100 in labor on the table just cause they're extra-honest and the maintsched says "inspect and correct as necessary every 30k/ 2 years"
Also note that its highly unlikely that a Dealer uses any different maintainace package for an ES, LX or RX. Just some different prices on the bottom line that you'll Authorize.
Also keep in mind that if you have 75,000 miles on your car, and bought it Used, even CPO'd - You may well have had a neglected or 'beaten on' vehicle. If the fluid isnt nice and red, definatly think about having a 'real' power flush done (~$200). And if the vehicle has been maintained at a Lexus facility, you can bank on the Tranny fluid having been drain/filled if any 15,000 interval service has been done.
A drain & fill is cheap preventative maintainance, if done correctly.
my .02
Lexus Connoisseur
I forgot to mention that one should drive the vehicle for a few miles before the 2nd fluid change. Thanks.
Lexus Connoisseur
Actually, I think your owner's manual and maintenance schedule in the ClubLexus library say to check the transmission fluid every year or two and change it when it is no longer the original red color.
There have been recent threads advising not to do a flush, but rather drain and refill with Toyota trans fluid every year ot two. $200 is ridiculous for just a drain and refill and I'd do it myself instead of paying that much. It takes about 2 quarts, and just make sure to use the special Toyota fluid.
Lexus Connoisseur
Lexus Connoisseur
Originally posted by toy4two
I thought the RX300 took 4 quarts of tranny fluid on a drain and refill not 2?
